So things progress a little further, I have the control surfaces attached and the graceful curves look just great! After drying overnight I then built my replacement wheel for the co-pilot and placed both canopies. The underside bombardiers canopy needed a little finesse to get a good fit but I found it very easy to get it to do so. The canopy over the flight deck just needed a couple of licks with the scalpel to remove a little flash and it settles right down into place. I have the bombardiers canopy masked and I just need to do the same to the cockpit canopy. Then it's onto painting the base camouflage before working out just how to proceed with the mottle.
After painting the interior of the spats and the wheels I assembled them as per instructions. The wheels themselves look good with a good level of detail but once ensconced inside the spats little will be seen. I then attached the supports to the spats and carefully followed the instructions but realised as I was putting it together that Italeri had the part numbers reversed and the fairings for the supports that attach to the fuselage sloped the wrong way. I suggest that you look carefully at the parts as you assemble them and be aware of this possibility, as although I felt I was careful I may simply have gotten the parts wrong.
Italeri also provide slight outlines on the wing surface where they think the supports should sit but I found them to be way off. Everything was assembled while still "wet" so there would be some adjustment possible to get the wheels straight and the angle of the spats relative to the wheel flats correct once assembled. Which proved somewhat tricky and I felt I needed another pair of hands whilst putting it together.
While the spat supports had tabs and slots to fit into there was nothing between the spat and the part mounted to the wing. I went about by gluing this butt joint first and then gently adjusting the assembly till the supports contacted the wing and I could flow Tamiya extra thin cement into the slight gap. After both sides were done and were drying I put the plane on it's landing gear to check that the flats on the tyres sat flat on the ground and much to my pleasant surprise they were spot on. see accompanying pics to see for yourself.
I think a more positive attachment between wing mounts and spats would be helpful here. I did toy with the idea of pinning it but put it aside because I felt that a little "play" was essential to get a good fit to the wing for the spat supports. And all in all it worked better than I thought it might.
She certainly looks more and more like a proper aircraft as this build proceeds, but I guess you could say that of just about any kit you build.
