Ammo box recorded on aluminum sheet, cut with shears and bent and made also other side. Completed and attached compass, as well as the seat with belts. Made also a new cover for the empty ammo box. On the tank filler neck for gasoline and oil, as well as ports for the fuel gauge used. Cheers Martin
The ammunition box is completed. I ordered a propeller of Copper States and get. He is very handsome! Unfortunately, the shape is not quite as I need them. So it must be reworked to the hub (too large) and sheet (form). On the pictures you can see a prop as I had already precut him. Cheers Martin
