Hello, gents.
Update time.
@Karl: Thanks again for generously sharing your knowledge.
@All: inspired by your post and comments, I changed the appearance of propellers by applying a dark satin filter. I am quite happy with the result; anyhow, it could be I'll add some final "scratches"
Again thanks to your comments, I changed the copper color on the "ammunition belt / oxygen hose" with brown, as seen on references. My last opinion is that the mold is awfully wrong. If my references are correct, the gun was fed from aluminum canisters, not from the belts. If the mold represents the sleeve protecting the cable, again is out of shape by way too much. Perhaps the best solution is to completely remove the detail and to replace it with a scratch build "sleeve". Anyhow, there is the pic:
I scratch built the hydraulic hoses from fishing line. The result is satisfying, unfortunately marred by the poorly molded detail:
Overall view with the wheel assembly. You can see also the air scoops were re-worked...
... and same thing with the turbo exhausts:
Only now I fully started to realize the sheer size of this thing. I think I need to expand my bench, or at least to radically re-organize it just to be able to handle this build
. For comparison, a 1/72 LaGG 3-35
Thank you so much for your valuable comments. Indeed, they were very helpful.
Gabriel
