Tamiya 1/48 F4U-1D CorsairSo I managed to break my own rules when I began to decal her. I have a routine I follow superstitiously when applying decals that might make some MLB players seem tame.
1. Buff the paint out with an old tee shirt to smooth surface imperfections before applying a gloss coat.
2. Distilled or RO water only to soak them.
3. Heat the water to a nice warm temperature and keep it there with a candle/soup warmer.
4. Go slowly and be patient. Save stencils for last in case you need to fix something.
Yeah, I threw that out the window right off the bat when I skipped buffing the paint and settled on lukewarm water. Basically I hadn't built a model in about 2 years and was in a hurry to finish one.
Big mistake. The decals were a somewhat older Aeromaster set but were still in great condition. They managed to fight me quite a bit which I chalk up to 100% user error.
The end result 24hrs later was a lot of dreaded silvering over my nice dark GSB paint. Ugh. I tried poking little holes and applied the whole arsenal to see if they wouldn't snug down. Micro Sol, Tamiya's Mark Fit Strong, even Walther's Solvaset which practically melts everything it touches. No luck. Well, it cleared up about 50% of the trouble but the rest was seriously stubborn.
I handled the port side insignia so much it ended up tearing and I had to try and piece it back together.
The cowling, landing gear, and wings all settled down nicely and cleared up under a second coat of Future, but not so for the fuselage. In the end I have decided I'm going to start over completely and try a set of masks instead. I'll scrub the paint job off this weekend with laquer thinner and then repaint her. I could just strip the bad spots but I don't have any way to source the correct numbers to match so I may as well go the whole distance.
I found a set of VF-84 masks from Montex designed for the Academy A/C/D multi-version kit. They should work nicely, especially since I still have all of the stencil decals.
I am not exactly thrilled with the risks of ruining the interior or other detailing I want to keep, but I have always wanted to try paint masks for a scheme. This one is at least simple and straightforward.
More to come...
