Hi Everybody,
Great stuff happening all over the site these days! Tim, I always like your little gems. Torsten, I'm watching your build with great interest.
Having never built an Eduard kit before, my first impression is "Wow!". The engineering and fit are something else. This is really a fun filled build for me.
The cockpit went together per the instructions without incident. Not real sure of the turquois interior color, playing with Tamiya paints I came up with something I thought was close enough for me.
The instrument panel and side decals worked great, and really make the interior pop. Another benefit is that they will be visible once inside!
While the instructions indicate that weight should be added, they don't tell you how much. I added around 17 grams of fishing weights using some 5 minute epoxy, more than enough I think.
The engine built up nicely, and I was able to get all the interior components in place so the fuselage could be closed up.
Once closed, I was impressed with the simple yet elegant look of the engine through the exhaust area.
After closing things up, construction moved very quickly!
Adding the flaps and ailerons were straight forward, though I did manage to get a finger print on one. Easily sanded off! The nice thing here is that if one wishes, with a little work, they can get the flaps down. Maybe in the future.
I'm currently going though a little seam cleaning (not much) and prepping the airframe for a NMF. This is a great kit so far, and I'm looking forward to playing with some metallic colors!
Till next time, keep having fun!
