Well, the silver lining to having to spend a few days locked in doors is that I've finally started to make some progress on the build!
Admittedly, it's just basic painting at the moment, but progress is progress.
I did a quick and dirty wood finish on the cockpit floors with poster paint and sealed it with Klear prior to applying some AK "Worn Effects" fluid and a top coat of black acrylic:
Scrubbing it gently revealed the "wood" as though the black non-slip paint had been worn through by the pilot's heels (I'll show the result later). Was it worth the hassle? To be honest, for the small amount of scuffing I depicted, probably not - dry-brushing with tan would have looked pretty much the same. But the "Worn Effects" worked perfectly and is definitely useful to have.
So - the current state of play is that the basic interior colours for the fuselage and wheel wells are sprayed on, and I've given everything a coat of Klear that I'll let dry overnight before starting weathering and shading with oil paint tomorrow and doing some more detail painting:
As you can see in the cockpits, I've used Eduard's pre-coloured placards in both, but I've left the moulded detail in one of them and used the etched fascias in the other for comparison.
More soon.
