1/72 FM-2 Wildcat Arma Hobby double build
litespeed
KitMaker: 1,976 posts
AeroScale: 1,789 posts
Posted: Friday, July 31, 2020 - 07:30 PM UTC
Really like the engine bay Magnus, good amount of detail for anyone wanting to do an engine change diorama
magnusf
KitMaker: 1,953 posts
AeroScale: 1,902 posts
Posted: Friday, July 31, 2020 - 07:56 PM UTC
Really like the engine bay Magnus, good amount of detail for anyone wanting to do an engine change diorama![]()
Tim! You're absolutely right! The kit is lovely and it is a fun build but to realise it's full potential it really should be part of a diorama to show off all the detail that will be hidden!
Magnus
Posted: Sunday, August 02, 2020 - 12:00 AM UTC
Continuing the trend of impressive work Magnus!
Those cockpits look great!
magnusf
Posted: Friday, August 21, 2020 - 06:50 AM UTC
Slowly forward...
The recognition lights below the fuselage are cast with the fuselage halves creating a tricky filling and sanding operation. I drilled them out, added plastic stock...
...and sanded them to shape.
A quarter of a century behind everyone else, I finally got around to testing pre-shading...
...the main reason being that the US machine is just white and grey and I felt this could be a good way to achieve a more interesting finish.
And this is how it turned out after painting it "white", a 95/5 mix of pure white and "russian black" from MrP.
I haven't really decided what I think about the result but the method isn' rocket science and the process was rather fun
Magnus
Magnus
litespeed
Posted: Friday, August 21, 2020 - 09:18 AM UTC
So impressed with the detail of this kit Magnus, your build is coming along nicely. Looking forward to ARMA release of the 1/72 scale Hurricane IIb.
I must admit I do like pre-shading its good fun. Personally I think youre pre-shading is a little too subtle Magnus, but it will be interesting to see how it turns out...
Posted: Friday, August 21, 2020 - 02:10 PM UTC
Magnus, you and me both, brother
meanwhile, progress is good
magnusf
Posted: Saturday, August 22, 2020 - 07:55 PM UTC
Tim and Russell! I'll continue experimenting, especially on light coloured and monochrome subjects!
Regarding the Hurricane, I've done (and bought
) enough of them for now but a IIa from Malta would probably trigger a few clicks in Arma's web shop. And I'm sure it will turn up in due course, Wojtek is heavily into stuff Hurricane for the time being
I realised that to get the camo right I had to locate the national insignia on the fuselage beforehand so time for some masks! I've started to build a little library of masks by now so these came from my 2017 Spitfire VIII build and just had to be re-scaled a bit
I have found the masking film a bit on the stiff side every now and then but even though this one needed to be bent into the concave curve along the fuselage it went very well this time!
Strictly not the fuselage but I did this one anyway while I were at it. And for a bit of practice since it is away from plain sight
I painted a slightly whiter white (on photos one can see a clear difference between the white of the insignia and the white of the camo) before adding the masks for the stars and the "ears".
And then a mix of Gunze H5 "Blue" darkened with black...
...and finally my favourite part of this, peeling away the masks
Magnus
Magnus
litespeed
Posted: Saturday, August 22, 2020 - 08:48 PM UTC
Just fantastic Magnus, much better looking than decals. Must give it a try sometime
Posted: Sunday, August 23, 2020 - 11:36 PM UTC
good work on the insignia Magnus!
BlackWidow
KitMaker: 1,732 posts
AeroScale: 1,336 posts
Posted: Monday, August 24, 2020 - 06:29 AM UTC
I second the words of Tim and Russell, Magnus. Great work on spraying the insignias! Well done!
magnusf
Posted: Friday, August 28, 2020 - 08:01 PM UTC
Friends! Thanks
Another weekly summary today!
Canopy masks are on and I've prepared the FAA one for masking the yellow fuselage codes later.
Walkways and canopy framing painted...
...and the US Navy machine masked and ready for painting!
I used rolled ParaFilm for the paint demarcations and while it is a bit on the stiff side to handle it sticks well when pressed down and I prefer it to masking putty for the time being!
Paint! Tamiya XF-54 and MrP clear in a 50/50 ratio, thinned using MrP thinner.
I very seldom use Tamiya paints so I have forgotten how incredibly matte they are. Even with 50% of gloss clear they barely turn satin
Not bad
I might go back and adjust the camo around the national insignia so that it follows the outline of it better.
Magnus
Not bad
Magnus
Posted: Friday, August 28, 2020 - 10:19 PM UTC
Neat work Magnus, looking good. You don't often see the Wildcats in this scheme, I like it!
litespeed
Posted: Friday, August 28, 2020 - 11:20 PM UTC
Looks really good Magnus, it really improves the look of the model with that slight variation in colour, particularly on a naval aircraft. That is around the ratio of paint to thinner I use. Nicely done Magnus
rdt1953
KitMaker: 1,098 posts
AeroScale: 900 posts
Posted: Saturday, August 29, 2020 - 12:26 AM UTC
Very nice Magnus - your pre shading looks very good indeed!
magnusf
Posted: Sunday, August 30, 2020 - 12:11 AM UTC
Damian! I was a bit hesitant in choosing the Atlantic camo for one of them but I find it rather attractive now!
Tim and Richard! I'll use preshading more in the future, especially on single-colour and light subjects!
Tour de France has started but I've managed to find a bit of time for some further modelling anyway
Masking continues, for markings on the US one and for the first camo colour (AK RC294 "Dark Slate Grey") for the FAA one.
Lots of tape... I have to hurry with the camo since I'm really curious how the yellow letters will look
Slate Grey. Rather uninspiring really
Last of the stars-and-bars painted on and a couple of "3"s. I had it all covered in tape while I did the painting but it was so ugly that I removed the tape before taking the photo. Sorry, I know it is cheating
That´s it! Next step will be stencilling and a pair of "3"s on the cowling that were too small for cutting as masks.
Magnus
Magnus
BlackWidow
Posted: Sunday, August 30, 2020 - 03:50 AM UTC
Both kittys are coming along nicely, Magnus! I have to try that Atlantic Camo Scheme also one day. Those painted insignias look great. Very well done!
Hey, you're swedish! No ice hockey?
.... Tour de France has started but I've managed to find a bit of time for some further modelling anyway...
magnusf
Posted: Wednesday, September 02, 2020 - 08:07 AM UTC
Torsten! Sorry, no hockey! I have been to a few games though and I understand what people see in it, it is 3x20 minutes of pure action no matter if goals are scored or not. Which is more than you can say about a five hour flat-land TDF-stage where everything is decided during the last 10 minutes...
Masking took a while (and was boring, another reason for going slowly...) but was finally done tonight.
Wings were masked using masking film cut over a copy of the planview scaled to the correct size in my printer while the tape on the fuselage was a much more laborious process...
Paint! This one is AK as well, this time it is RC295 once again mixed with MrP clear and thinned with MrP thinner. Works like a charm!
Camo masks removed...
...and best of all: the codes! This exact part of the process is worth all the tape work!
It is NOT the Elbonian Air Force, I have decided to use the roundel decals on this one and left the white primer under circular masks to get a good background for them. As for the fin flash, it will have to make do without...
Tomorrow is most likely decal time
Magnus
Magnus
Posted: Wednesday, September 02, 2020 - 09:23 AM UTC
Magnus, this is amazing work!
I'm especially impressed with how you made the masks!
What are our chances that you could do a bit of a detailed Step By Step of how you create them, and details of the masking film you use?
magnusf
Posted: Thursday, September 03, 2020 - 07:50 AM UTC
Russell! I might very well do in the future!
I did the big and fun decals tonight, saving the stencilling for tomorrow...
I used the original Arma decals, printed by Techmod, absolutely top notch!
Magnus
Magnus
magnusf
Posted: Sunday, September 13, 2020 - 05:33 AM UTC
After a week of general tardiness and messing around with some other models (which I shouldn't...) I'm back to the Wildcats for the weekend!
I've done the stencilling, not too much but I'm not very fond of it so that might be the reason for the slow week...
After a wash, using MiG Productions "Cold Grey Wash" on the American machine and my absolute favourite Ammo "Dark Brown Wash for Green Vehicles" on the British one.
Magnus
Magnus
Posted: Sunday, September 13, 2020 - 05:44 AM UTC
Wow, Magnus, these are exceptional. I gotta try masks now.
SHAKY962
KitMaker: 765 posts
AeroScale: 316 posts
Posted: Sunday, September 13, 2020 - 09:28 AM UTC
Excellent Magnus!!!!!
Posted: Sunday, September 13, 2020 - 12:55 PM UTC
Magnus! I'm always impressed how you can build 2 kits concurrently at the same time...
I find I really struggle with doing that-kind of like trying to drive 2 cars across a desert at the same time
As always, your builds are a masterclass in 1/72 aircraft!
magnusf
Posted: Friday, September 18, 2020 - 06:59 PM UTC
Frederick! Masks and decals are a bit mix-and-match on these, I opted for decals for the FAA roundels!
José! Thanks
Russell! I've had my ups and downs with building more than one at a time. The first part of the process where everything is more or less the same (most of the build, painting cockpits, landing gear, engines - you get it!) has potential for saving some time compared to building the models sequentially but later on there isn't much to gain usually, especially if the paint schemes differ. The major drawback is that if you get stuck with some boring or tricky part of the build, there is twice the amount of that to get through at the same time. Anyway, I bought too many of these by mistake so I better get them built right away, otherwise they probably would get stashed indefinitely
Engine installation in progress! I removed the cowlings that had been temporarily installed for the painting process. Radials without cowlings always makes me think about crop dusters! Not much left do to, maybe I will be able to finish these this weekend.
Magnus
José! Thanks
Magnus
litespeed
Posted: Friday, September 18, 2020 - 11:24 PM UTC
Looking really good Magnus, they make a great pair. You enjoying the tour de france?
