World War II: Great Britain
Aircraft of Great Britain in WWII.
Building Tamiya's 1/48 Lancaster
KelticKnot
_VISITCOMMUNITY
Scotland, United Kingdom
KitMaker: 768 posts
AeroScale: 656 posts
Posted: Thursday, October 27, 2016 - 07:10 PM UTC
More decalling ups and downs :
Antilles
_VISITCOMMUNITY
Nordrhein-Westfalen, Germany
KitMaker: 671 posts
AeroScale: 614 posts
Posted: Thursday, October 27, 2016 - 07:34 PM UTC
Paul,
Your custom decals are really fine! I have never done or seen this before. Maybe You can do a tutorial!
Thanks for sharing!
Oliver
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Thursday, October 27, 2016 - 08:42 PM UTC
Thank you Oliver!
I will maybe think about doing a simple tutorial once I've mastered the technique a little better.
Things like nose art are always going to be very difficult to reproduce any other way than using decals but I'm wondering if it's better to mask and paint the larger stuff especially code letters.
Staff MemberAssociate Editor
AUTOMODELER
_VISITCOMMUNITY
New York, United States
Posted: Thursday, October 27, 2016 - 09:04 PM UTC
Paul,
Masking instead of decaling yield a real painted on finish, that the best decals and application can only hope to equal. Most of my decaling has some flaw caused by me, the decals, the paint, or any combination. I've thought about trying to learn Masking/painting for at least the various National Insignias, but at my age learning that skill is something that I keep on putting off.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Friday, October 28, 2016 - 01:28 AM UTC
As you can see there is a nasty white edge around the decal.
I made sure to cut inside the blue of the roundel and gave the decal an extra coat of sealant.
I think the problem is simply that cutting the decal from the sheet breaks the seal and the water can attack the ink.
You can also see where I sliced the decal to allow it to conform to the shape of the raised area in the top right. Again, this breaks the seal and using microset to help the decal lay down has lifted the ink.
It's frustrating as the decal paper is excellent. It's super thin and very strong if only I could overcome this problem with the inkjet ink.
I considered applying sealant around the cut edge of the decal but I'm worried that might bond it to the paper and not allow it to slide off easily.
simonn
_VISITCOMMUNITY
Australia
KitMaker: 62 posts
AeroScale: 36 posts
Posted: Friday, October 28, 2016 - 05:45 AM UTC
Paul
I think those decals look great. The 'lack of a crisp finish' may well be accurate to the original and the nose art is especially good. I met a bomb aimer last Christmas, Laurie Woods, and intend on modelling his aircraft so willl need to get decals printed also. Although I may try painting the insignia.
Simon
Redhand
#522
_VISITCOMMUNITY
New Jersey, United States
KitMaker: 1,460 posts
AeroScale: 1,443 posts
Posted: Friday, October 28, 2016 - 06:26 AM UTC
I LOVE your research. That's the way to make a great model!
goodn8
_VISITCOMMUNITY
Berlin, Germany
KitMaker: 709 posts
AeroScale: 651 posts
Posted: Friday, October 28, 2016 - 11:54 AM UTC
Paul your decals are come out nicely but you can only avoid the white edge by using transparent decal film (highly recommended by own experiences!).
Since the paper is white, the edges stay white (unless you touch them up & seal again after cutting).
The problem with the trancparency is - you cannnot print "white". So you need to paint parts (small roundels or inner sections) before applying the decal and only use the white paper when there's no other way or the white is already at the edges.
But don't worry at all - your build is great and after weathering it won't be seen.
Thomas
goodn8
_VISITCOMMUNITY
Berlin, Germany
KitMaker: 709 posts
Posted: Friday, October 28, 2016 - 12:06 PM UTC
EDIT: as my first attempt to custom decals I did it on my Bristol B. - printed on transparent film & brushed roundels...
Merlin
Staff MemberSenior Editor
AEROSCALE
#017
_VISITCOMMUNITY
United Kingdom
KitMaker: 17,582 posts
AeroScale: 12,795 posts
Posted: Saturday, October 29, 2016 - 12:55 AM UTC
Hi Paul
I've got to say, I'd go with masks if there aren't suitable aftermarket decals available. After the amazing work you've put into the build of this model, I reckon it'll gnaw at you of the markings aren't up to a similarly high standard.
Roundels are no problem to cut from Frisket film etc., but (while I shouldn't speak for him) I reckon Mal might be only to pleased to help out with some Miracle Masks on an outstanding project like this...
Redhand
#522
_VISITCOMMUNITY
Posted: Saturday, October 29, 2016 - 01:44 AM UTC
Hi Paul
Paul: I tend to agree with Rowan on this. Everything you've done to date has been so extraordinary that second-best won't do. I'm not sure if there are masks for wing insignia for the Lancaster, but there are many aftermarket decals that are available. Here are some below.
http://www.ultracast.ca/products/Limited%20Stock/AeroMaster/48-Scale/48-453/
http://www.kitsworld.co.uk/index.php?CATEGORY=4&SUB=6&THISPAGE=1&RADIOSORT=4&PICFILE=435&STKNR=435&STRH=3808&ORDN=2585&RNZ=355709
https://www.hannants.co.uk/product/TM48801
Surely they cannot all be the wrong diameter?
PS, I really like your nose art and I have no issue at all with the squadron letters. They're not "perfect" but they certainly look realistic to me, and squadron codes naturally will have been painted by ground personnel on the base so one wouldn't expect them to be "letter perfect" (pun intended!).
Good luck.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Saturday, October 29, 2016 - 04:16 PM UTC
Thanks for your support guys.
Rowan, great minds obviously think alike as I've already approached Mal on the subject of paint masks.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Wednesday, November 02, 2016 - 05:23 PM UTC
The outboard props on both sides sit a few millimetres proud of the engine casing so a little adjustment is needed on the the prop shafts.
Merlin
AEROSCALE
#017
_VISITCOMMUNITY
United Kingdom
Posted: Thursday, November 03, 2016 - 03:09 AM UTC
Hi Paul
Good catch. It's interesting that the outboard spinners on both wings are mis-aligned.
Redhand
#522
_VISITCOMMUNITY
Posted: Thursday, November 03, 2016 - 08:56 AM UTC
Whoa! I can't wait to see more of the exterior on this bird.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Sunday, November 06, 2016 - 06:50 PM UTC
Rowan, a tiny issue in the grand scheme; a quick sand of the prop shafts to reduce the length and the all the spinners sit equally.
Brian, I am happy to oblige !
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Sunday, November 06, 2016 - 06:51 PM UTC
Redhand
#522
_VISITCOMMUNITY
Posted: Sunday, November 06, 2016 - 11:44 PM UTC
Looking really good, Paul!
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Wednesday, November 09, 2016 - 08:23 PM UTC
I'm ready to try out Mal's paint masks tomorrow with any luck so last preparations :
I reckon I've mixed plenty of paint, let's hope it's enough !
AUTOMODELER
_VISITCOMMUNITY
Posted: Thursday, November 10, 2016 - 12:59 AM UTC
Paul,
Seems I've been rather missing from the party as of late, so I've spent some time catching up from my last post.
Using Mals Masks for the markings and Roundels is really the best idea. Done correctly, they're better then the best decals. Can't wait to see how you apply them, and how they come out. Please do a well detailed update on their application.
Your creation of the plate to cover the removal of the turret really came out great. The roughness of the primer does indeed add to the over all effect.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Thursday, November 10, 2016 - 02:51 AM UTC
Always good to hear your comments Joel, thanks.
I must admit to some nerves regarding the paint masks. I'm sure it'll be fine but I'm trying a new technique without the benefit of a test run.
I'll be sure to give a detailed account of their use from the viewpoint of a first time user.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Thursday, November 10, 2016 - 09:08 PM UTC
Overall, I found the masks very simple to use once I'd become accustomed to the way they behave.
Detailed paint mask blogging to come.
AUTOMODELER
_VISITCOMMUNITY
Posted: Friday, November 11, 2016 - 12:11 AM UTC
Paul,
the F indeed looks painted on because it was painted on.
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Friday, November 11, 2016 - 03:50 PM UTC
It certainly seems to beat messing around with decals; hoping they don't break into pieces, battling to get them to settle down with setting solutions and trying to avoid silvering....
Without any doubt the tricky aspect to using the masks is accurately replacing them to to re-mask a painted area.
Here's my take on the process:
KelticKnot
_VISITCOMMUNITY
KitMaker: 768 posts
Posted: Friday, November 11, 2016 - 03:54 PM UTC
