1⁄35The Mother Child ReUnion
8
The Cart for the “Goblin” was a nice and necessary feature (as the XF-85 has no gear). Not willing to leave well enough alone, I did make a couple of modifications here.
I added small pieces of wire to the front supports of the Cart and drilled to small holes in the fuselage of the XF-85, this to make the aircraft removable from the cart. I also added a small “saddle” to stabilize the aircraft while resting on the Cart.
Two of the photos of the “Goblin” show the results of the Metalizer application. I used MM (buffing) Aluminum Metalizer, for this project. I have used Alclad and SnJ in the past, but wanted to give the MM product a try. Frankly I’m glad I did.
The MM Aluminum Metalizer (Buffable) goes on as sort of a “fuzzy”, dull Aluminum. It’s easy to apply, as there is no need to prime the surface, just make sure you have a clean, blemish free surface as EVERYTHING SHOWS. The surface detail is quite visible as is every scratch, file/sanding mark, extra drop of glue and any dust.
As the “Goblin” was to have a highly polished surface sheen, I actually invested in a pair of white cotton gloves just to handle the model; boy, am I glad I did, I really needed them later. From past experience I knew that applying a gloss coat would tone down any buffed finish, I therefore buffed the entire aircraft to a relatively high sheen, using a cotton cloth. After applying the Clear coat, and letting it cure for a day, I re-polished selected areas using SnJ powder and a motor tool. I then applied the Decals, painted the color detail, and applied a second light coat of clear, overall except the anti-glare panel.
The last two pieces to be fixed to the model were the canopy and the “skyhook”. This was done together, as the canopy and “skyhook” alignment to each other is critical. I painted the vacuum-formed canopy framing after it was in place; with a toothpick and my favorite bare metal trim paint, a bottle of at least 10-year-old Testor’s Silver. This particular bottle of paint has been special for me, it is very smooth in consistency and provides a very bright metal looking surface. Since I only use this paint for special purposes; i.e. bare Metal frames and landing gear components, this bottle probably has another 10 plus years of painting left in it. The toothpick painting method is something I adopted several years ago, I make no claim to having come up with the idea, I just can’t remember where I saw it used. I started using the method, as I remember, just before they started selling Micro Brushes. Having tried Micro Brushes, I’ll stay with the toothpick method. I find it an effective way to apply paint to a very small area, and use it for figure painting as well as canopies. You can vary the width of line to be laid down by carving the toothpick. Carefully controlling the amount of paint on the toothpick you simply draw the detail. Unfortunately, as you can see in close-ups, my hand is not as steady as it used to be, but I still like the result.
That looks fantastic Chuck.
How big is it in size, i remember building the Airfix B-29 when i was a kid and its huge.
Some great details added to the whole thing, and the lights definitely add realism to the scene.
To tell the truth i have always thought of recreating the parasite/ test aircraft and mother craft, such as the X-15 being carried by a B-52, but i thought of only recreating the wing section of the B-52, so not to distract from the "real" aircraft of the piece. But with so much detail in your dio, I'm having second thoughts (but then again, space is an issue :-) ).
Andy
OCT 09, 2006 - 02:57 AM
Howdy Chuck
As I said in another thread {you know, the one where I nearly let the 'cat-out-of-the-bag'}, your dio looks superb! I didn't realize that I was giving a 'preview' of your outstanding work when I posted that pic of your Goblin in that other thread.......at least it was the box art and not the actual model
You did a great job on the NMF on both aircraft......it really looks great. And the open engine nacelle is well done and conveys a nice sense of 'activity'....nicely done. Your scratchbuilt trough-like bay undernerath the B-29 and depicting the workmen busy around the X-85 is an absolutely outstanding idea!......and one extremely well accomplished!
What can I say.....I love it!
Tread.
OCT 09, 2006 - 03:18 AM
Hi Chuck
Fantastic! I don't know about a "mother and child reunion" - I've been pacing up and down outside the delivery room waiting to see this baby finished! Thank goodness I don't have to pretend I like cigars anymore! :-)
Seriously, it is a superb build and diorama - the level you've taken the old 1960's Airfix B-29 to is amazing! And the atmospheric night shots are the icing on the cake!
Something's missing! - ohh yeah - I didn't use the word "spectacular"! (in joke) :-)
P.S. I still say it's spectacular!
OCT 09, 2006 - 03:25 AM
Andy,
it's 45 x 61 cm there is a reason I build in 1/72 scale
A B-52 Dio would be MUCH larger, thought of that one myself but SPACE is a problem. :-)
Maybe in 1/144
P.S. Thanks all of you for the Kind remarks
OCT 09, 2006 - 03:45 AM
Brilliant Andy, I like the unusual or esorteric and this one certainly makes the grade. I like the idea of lighting the pit, very effective. W.O.W!
Must google the XF-85 - by the look of it it might have been a bit of a handful.
Jeff W.
???Andy?? Humble apologies CHUCK!
OCT 09, 2006 - 03:58 PM
Hi Chuck:
Wow, just a super well detailed article and a great job of modeling with
that very old Airfix Super Fortress kit. Love your diorama idea and how it
all came together at the end. Thanks for taking time to shoot all the pix
WIP, during the build and for the time involved in this very comphrensive
article. Discipline? Wow, you've got plenty of that. Congratulations
OCT 09, 2006 - 04:38 PM
Hi Chuck.
This is a great diorama, and while reading the article its easy to see how it evolved and became what it ended up as,,a fabulous work!
I enjoyed reading about how you used the metalizers, something I havent tried and it looks really good.
What makes this stand out for me though is how youve used lights in the "inspection pit",,it really brings the diorama to life and adds a whole new level to the work generally.
Congratulations on a job well done.
Nige
OCT 12, 2006 - 04:07 AM
Yes Andy, you can build Dios in smaller scales :-) I just finished this one in 1/144 :-) It's only 11 x 14 inches.
DEC 01, 2006 - 02:08 AM
Copyright ©2021 by Chuck Shanley. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2006-10-09 00:00:00. Unique Reads: 9085
