1⁄35The Mother Child ReUnion
8
At last, a big silver airframe. This is where the cotton gloves I mentioned earlier come in handy. Typically no aircraft has a consistent overall finish, and this is particularly noticeable on a NMF aircraft of large size. To achieve the inconsistent tonal quality of the aircraft, I used buffing to various degrees, as well as no buffing at all in some areas. This is the strength, in my opinion, of buffing metalizers. You can achieve varying textures using buffing techniques. I used a cotton cloth, cotton swabs and a motor tool with a buffing wheel to get variations, along with no buffing at all. At this point the assembled portion of the airframe contains five variations of Aluminum Plate, from one paint application and some buffing, all be it days of buffing, worth the effort to achieve the effect. The NMF was then given a coat of Gloss, and the big yellow tail section was painted. The B-29 kit National Insignia decals were of the wrong era, for this aircraft, so I replaced them with after market decals from my stash. The tail number had to be “constructed” from individual numbers, again from my stash of decals. The big brown throw pillow you may notice in some of the photos is to protect the NMF from any marring or contamination.
With the major components assembled and painted, I proceeded to attach the landing gear, and Tail control surfaces (which were finished separately, not painted but finished by simply applying SnJ silver polishing powder directly to the plastic by buffing and no gloss coat applied), and balance the aircraft by weight adjustment (more than the initial added weight was needed). To this point, except for the removal of the turrets, the B-29 was an Out of the Box build (soon to change).
The only rework that was truly required was on the engine cowls. The “Gills” area was much too thick and required thinning, and the “Gills” needed to be separated. This went pretty quickly, thanks to a motor tool and a razor saw. Applying SnJ powder with a cotton swab, and buffing then finished the nacelles. Here again no gloss coat was applied. As a finishing touch, I applied “burnt metal” Metalizer to the leading edge of the cowls, to produce a darkened look I had observed in several research photos.
Some of the things, I’m about to discuss, were necessary; others, well, I said I did some experimenting.
The Engines provided were a little plain, so I decided to experiment with a bit of detailing. Nothing much just a few added bits, with wire an solder I added some “piping” to one engine, and decided one was enough (sanity must prevail some time). However, having done some work on the Engine I decided I would show it exposed somehow. Using reference photos, I attempted to construct the configuration of an engine under servicing. As is usual for me, I did not want to proceed without a way to back out. So, instead of cutting up the kit provided cowling, I used a cowling from an old P-47 kit I had on hand. The P-47 cowl required some minor rework, basically the construction of the “double chin”. After place it on the front of the Engine, I added strapping (plastic strips) to represent the normal understructure, and made some “Gills” from paper stock.
Rework, Modifications and Add-Ons etc. etc. etc.
Just a reminder, the B-29 was to be constructed as a backdrop for the purpose of displaying the XF-85 “Goblin”.The only rework that was truly required was on the engine cowls. The “Gills” area was much too thick and required thinning, and the “Gills” needed to be separated. This went pretty quickly, thanks to a motor tool and a razor saw. Applying SnJ powder with a cotton swab, and buffing then finished the nacelles. Here again no gloss coat was applied. As a finishing touch, I applied “burnt metal” Metalizer to the leading edge of the cowls, to produce a darkened look I had observed in several research photos.
That looks fantastic Chuck.
How big is it in size, i remember building the Airfix B-29 when i was a kid and its huge.
Some great details added to the whole thing, and the lights definitely add realism to the scene.
To tell the truth i have always thought of recreating the parasite/ test aircraft and mother craft, such as the X-15 being carried by a B-52, but i thought of only recreating the wing section of the B-52, so not to distract from the "real" aircraft of the piece. But with so much detail in your dio, I'm having second thoughts (but then again, space is an issue :-) ).
Andy
OCT 09, 2006 - 02:57 AM
Howdy Chuck
As I said in another thread {you know, the one where I nearly let the 'cat-out-of-the-bag'}, your dio looks superb! I didn't realize that I was giving a 'preview' of your outstanding work when I posted that pic of your Goblin in that other thread.......at least it was the box art and not the actual model
You did a great job on the NMF on both aircraft......it really looks great. And the open engine nacelle is well done and conveys a nice sense of 'activity'....nicely done. Your scratchbuilt trough-like bay undernerath the B-29 and depicting the workmen busy around the X-85 is an absolutely outstanding idea!......and one extremely well accomplished!
What can I say.....I love it!
Tread.
OCT 09, 2006 - 03:18 AM
Hi Chuck
Fantastic! I don't know about a "mother and child reunion" - I've been pacing up and down outside the delivery room waiting to see this baby finished! Thank goodness I don't have to pretend I like cigars anymore! :-)
Seriously, it is a superb build and diorama - the level you've taken the old 1960's Airfix B-29 to is amazing! And the atmospheric night shots are the icing on the cake!
Something's missing! - ohh yeah - I didn't use the word "spectacular"! (in joke) :-)
P.S. I still say it's spectacular!
OCT 09, 2006 - 03:25 AM
Andy,
it's 45 x 61 cm there is a reason I build in 1/72 scale
A B-52 Dio would be MUCH larger, thought of that one myself but SPACE is a problem. :-)
Maybe in 1/144
P.S. Thanks all of you for the Kind remarks
OCT 09, 2006 - 03:45 AM
Brilliant Andy, I like the unusual or esorteric and this one certainly makes the grade. I like the idea of lighting the pit, very effective. W.O.W!
Must google the XF-85 - by the look of it it might have been a bit of a handful.
Jeff W.
???Andy?? Humble apologies CHUCK!
OCT 09, 2006 - 03:58 PM
Hi Chuck:
Wow, just a super well detailed article and a great job of modeling with
that very old Airfix Super Fortress kit. Love your diorama idea and how it
all came together at the end. Thanks for taking time to shoot all the pix
WIP, during the build and for the time involved in this very comphrensive
article. Discipline? Wow, you've got plenty of that. Congratulations
OCT 09, 2006 - 04:38 PM
Hi Chuck.
This is a great diorama, and while reading the article its easy to see how it evolved and became what it ended up as,,a fabulous work!
I enjoyed reading about how you used the metalizers, something I havent tried and it looks really good.
What makes this stand out for me though is how youve used lights in the "inspection pit",,it really brings the diorama to life and adds a whole new level to the work generally.
Congratulations on a job well done.
Nige
OCT 12, 2006 - 04:07 AM
Yes Andy, you can build Dios in smaller scales :-) I just finished this one in 1/144 :-) It's only 11 x 14 inches.
DEC 01, 2006 - 02:08 AM
Copyright ©2021 by Chuck Shanley. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2006-10-09 00:00:00. Unique Reads: 9085
