1⁄35The Mother Child ReUnion
8
At this point I mounted all but the “exposed” engine to the airframe, along with the canopy (the framing if which was painted in place, using a toothpick and my special bottle of silver, I mentioned earlier), and other clear components. Why not mount the “exposed” engine, you ask? There was a lot of additional handling to take place.
Both aircraft were now essentially complete, now they could be used to provide me with reference as to the proportion of the Diorama base features, and other Add-On components. Granted the Diorama base is pretty simple, after all it’s just a big flat piece of aircraft parking area, with one little difference, it’s got a big ramp and pit in it. I needed the XF-85 “Goblin” to figure out the depth and width of the pit, and the B-29 to figure the length. With the pit constructed, I needed both aircraft in their “final” positions the figure out the most important part of the Diorama, the “Trapeze”.
The “Trapeze” is the apparatus used to launch and retrieve the XF-85 “Goblin” from the aft bomb bay of the B-29. As mentioned but aircraft in their “final” positions were required to estimate the proportions of this apparatus. Having photos but no drawings I estimated the size of each section, and scratch build the apparatus in the partially deployed position ready to receive the XF-85 “Goblin”. The “Trapeze” was made from various standard sizes of Evergreen plastic rod, and a piece of solder bent to shape and painted to represent to “nose cradle”.
My goal was/is to show the B-29 as “Monstro” (the whale in Disney’s Pinocchio), in one of its incarnations as a “Mother ship” for test vehicles at Edwards AFB / Muroc Lake. This particular version is for the FICON, parasite fighter evaluation, before the B-36 became available.
Well there it is both Aircraft, the Diorama base, the “Trapeze” figured out and built, all in position; all done right? WRONG. Remember that “exposed” engine, well it now gets attached, but looks a bit plain. I constructed two “work platforms” using the same rod the “Trapeze” was made from and some corrugated sheet. Of course a couple of mechanic figures were needed to put the platforms to use. A few other figures were added to the work areas around the B-29 and “Goblin” as well as a Bomb Cart and Lighting Unit Generator, from a Hasegawa Ground Equipment Set, just to “fill out” the scene.
Oh and finally a little side building just knocked together really, to hold the batteries, for the lights under the B-29 and in the pit. The building was made using textured plastic sheet from Evergreen, originally intended as railroad car siding. I added the lights, really to call attention to the fact there was something going on under the B-29. Turns out the B-29 sort of overwhelms the diorama, simply due to its size. A single AA battery powers the lights. The large light in the Pit is a small flashlight bulb designed for single cell operation (Ray-O-Vac T1AAA), I found at Wal-Mart. The two smaller bulbs on the “work stands” are ones I found at the local Model Railroad Shop, I just selected the smallest I could find, they had an in-line resistor, as they are intended for 12 volt use, which I removed. The bulbs are simply wired in parallel, each bulb connected directly to the battery, this to provide the “best” brightness.
As I said previously, the Diorama took on an energy and mind of its own. Original plans for something simple soon went by the way side. With so many interesting features showing up in the reference photos, and having “invested” in building a fairly large Diorama, I incorporated several “extras”. Having been a “model builder” for some 50 years now, this is only my third attempt at building anything of this magnitude. I hope I have time left to do at least a couple more I have planned, in my head, as they do prove quite enjoyable, for me.
That looks fantastic Chuck.
How big is it in size, i remember building the Airfix B-29 when i was a kid and its huge.
Some great details added to the whole thing, and the lights definitely add realism to the scene.
To tell the truth i have always thought of recreating the parasite/ test aircraft and mother craft, such as the X-15 being carried by a B-52, but i thought of only recreating the wing section of the B-52, so not to distract from the "real" aircraft of the piece. But with so much detail in your dio, I'm having second thoughts (but then again, space is an issue :-) ).
Andy
OCT 09, 2006 - 02:57 AM
Howdy Chuck
As I said in another thread {you know, the one where I nearly let the 'cat-out-of-the-bag'}, your dio looks superb! I didn't realize that I was giving a 'preview' of your outstanding work when I posted that pic of your Goblin in that other thread.......at least it was the box art and not the actual model
You did a great job on the NMF on both aircraft......it really looks great. And the open engine nacelle is well done and conveys a nice sense of 'activity'....nicely done. Your scratchbuilt trough-like bay undernerath the B-29 and depicting the workmen busy around the X-85 is an absolutely outstanding idea!......and one extremely well accomplished!
What can I say.....I love it!
Tread.
OCT 09, 2006 - 03:18 AM
Hi Chuck
Fantastic! I don't know about a "mother and child reunion" - I've been pacing up and down outside the delivery room waiting to see this baby finished! Thank goodness I don't have to pretend I like cigars anymore! :-)
Seriously, it is a superb build and diorama - the level you've taken the old 1960's Airfix B-29 to is amazing! And the atmospheric night shots are the icing on the cake!
Something's missing! - ohh yeah - I didn't use the word "spectacular"! (in joke) :-)
P.S. I still say it's spectacular!
OCT 09, 2006 - 03:25 AM
Andy,
it's 45 x 61 cm there is a reason I build in 1/72 scale
A B-52 Dio would be MUCH larger, thought of that one myself but SPACE is a problem. :-)
Maybe in 1/144
P.S. Thanks all of you for the Kind remarks
OCT 09, 2006 - 03:45 AM
Brilliant Andy, I like the unusual or esorteric and this one certainly makes the grade. I like the idea of lighting the pit, very effective. W.O.W!
Must google the XF-85 - by the look of it it might have been a bit of a handful.
Jeff W.
???Andy?? Humble apologies CHUCK!
OCT 09, 2006 - 03:58 PM
Hi Chuck:
Wow, just a super well detailed article and a great job of modeling with
that very old Airfix Super Fortress kit. Love your diorama idea and how it
all came together at the end. Thanks for taking time to shoot all the pix
WIP, during the build and for the time involved in this very comphrensive
article. Discipline? Wow, you've got plenty of that. Congratulations
OCT 09, 2006 - 04:38 PM
Hi Chuck.
This is a great diorama, and while reading the article its easy to see how it evolved and became what it ended up as,,a fabulous work!
I enjoyed reading about how you used the metalizers, something I havent tried and it looks really good.
What makes this stand out for me though is how youve used lights in the "inspection pit",,it really brings the diorama to life and adds a whole new level to the work generally.
Congratulations on a job well done.
Nige
OCT 12, 2006 - 04:07 AM
Yes Andy, you can build Dios in smaller scales :-) I just finished this one in 1/144 :-) It's only 11 x 14 inches.
DEC 01, 2006 - 02:08 AM
Copyright ©2021 by Chuck Shanley. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2006-10-09 00:00:00. Unique Reads: 9085
