1⁄35The Mother Child ReUnion
8
Now The Mother Ship The B-29 Super Fortress kit by Airfix
I searched through my “stash” and came up with an idea. After a couple of weeks of research (mostly photo searches), and a lot of brain storming, I decided to use my old Airfix B-29 to show the “Goblin” in an operational state.The B-29 turned into quite a project on it’s own. Considering it was initially intended as a “backdrop” for display of the X-85. I not only had to construct most of the B-29 to establish the scale of add-ons, but because of all the wait time (for paint to dry and other components to be assembled) I did a lot of experimenting, with detail and paint, on it. The First meeting of the “Mother” and “Child” was quite inglorious. I placed the mostly complete “Goblin” in the B-29 box, just to contemplate what was ahead. My first thought was, “Are you crazy?” speaking to myself of course.
I’d like to say that the 29 was a straightforward build, but a couple of factors enter into the equation, first it’s an old kit and needs some work, second almost from the first piece I had to keep an eye out for modifications that may be needed.
The cockpit was spartan by today’s standards, and I didn’t do much to improve it. I was hoping that enough would be going on elsewhere that a cockpit wouldn’t matter much, as it is not really visible in 1/72nd scale. I did however at this early point have to start considering where to locate weights to balance the airframe. I also had to insert backing material for the areas where the turrets were to be removed.
The turret removal became a very long process. After the fuselage halves were fitted together the areas were puttied over with Squadron Putty and carefully worked back to the fuselage profile. I made a quite concerted effort to minimize the amount of surface detail loss. Oh, did I mention the kit has raised rivet detail. Here again I used the method, I described in the Goblin assembly, of sanding/filing then buffing with SnJ powder. This took place a number of times as you can probably imagine.
To be honest, I didn’t achieve the fit and finish I was hoping for, but I think I wound up with something that does look like a retrofit, which a revamp of the old bomber in fact was.
The next step was to build and fit the wings to the fuselage. The wings were pretty straightforward, a little filing and fitting, but not bad. My main concern was “will they stay on?” I was very surprised at how heavy the wings felt in comparison to the fuselage. In other large bomber kits I’d seen large wing spars to support the wings, but here none was provided. I actually voiced this concern to one of our fellow modelers, Merlin. I carefully fitted and glued them into place and supported them overnight, as he suggested, well they held. So far, so good.
Now it was time for the application of the NMF. This time I did do some priming over the areas where Squadron white putty had been applied, as they appeared very light when compared to the rest of the fuselage. For ease of application none of the clear canopy parts, landing gear, landing gear, or bomb bay doors were fitted. The engine nacelles were also left off at this time. I simply stuffed the bomb bay and cockpit areas with tissue and applied an overall coat of MM Aluminum Metalizer.
That looks fantastic Chuck.
How big is it in size, i remember building the Airfix B-29 when i was a kid and its huge.
Some great details added to the whole thing, and the lights definitely add realism to the scene.
To tell the truth i have always thought of recreating the parasite/ test aircraft and mother craft, such as the X-15 being carried by a B-52, but i thought of only recreating the wing section of the B-52, so not to distract from the "real" aircraft of the piece. But with so much detail in your dio, I'm having second thoughts (but then again, space is an issue :-) ).
Andy
OCT 09, 2006 - 02:57 AM
Howdy Chuck
As I said in another thread {you know, the one where I nearly let the 'cat-out-of-the-bag'}, your dio looks superb! I didn't realize that I was giving a 'preview' of your outstanding work when I posted that pic of your Goblin in that other thread.......at least it was the box art and not the actual model
You did a great job on the NMF on both aircraft......it really looks great. And the open engine nacelle is well done and conveys a nice sense of 'activity'....nicely done. Your scratchbuilt trough-like bay undernerath the B-29 and depicting the workmen busy around the X-85 is an absolutely outstanding idea!......and one extremely well accomplished!
What can I say.....I love it!
Tread.
OCT 09, 2006 - 03:18 AM
Hi Chuck
Fantastic! I don't know about a "mother and child reunion" - I've been pacing up and down outside the delivery room waiting to see this baby finished! Thank goodness I don't have to pretend I like cigars anymore! :-)
Seriously, it is a superb build and diorama - the level you've taken the old 1960's Airfix B-29 to is amazing! And the atmospheric night shots are the icing on the cake!
Something's missing! - ohh yeah - I didn't use the word "spectacular"! (in joke) :-)
P.S. I still say it's spectacular!
OCT 09, 2006 - 03:25 AM
Andy,
it's 45 x 61 cm there is a reason I build in 1/72 scale
A B-52 Dio would be MUCH larger, thought of that one myself but SPACE is a problem. :-)
Maybe in 1/144
P.S. Thanks all of you for the Kind remarks
OCT 09, 2006 - 03:45 AM
Brilliant Andy, I like the unusual or esorteric and this one certainly makes the grade. I like the idea of lighting the pit, very effective. W.O.W!
Must google the XF-85 - by the look of it it might have been a bit of a handful.
Jeff W.
???Andy?? Humble apologies CHUCK!
OCT 09, 2006 - 03:58 PM
Hi Chuck:
Wow, just a super well detailed article and a great job of modeling with
that very old Airfix Super Fortress kit. Love your diorama idea and how it
all came together at the end. Thanks for taking time to shoot all the pix
WIP, during the build and for the time involved in this very comphrensive
article. Discipline? Wow, you've got plenty of that. Congratulations
OCT 09, 2006 - 04:38 PM
Hi Chuck.
This is a great diorama, and while reading the article its easy to see how it evolved and became what it ended up as,,a fabulous work!
I enjoyed reading about how you used the metalizers, something I havent tried and it looks really good.
What makes this stand out for me though is how youve used lights in the "inspection pit",,it really brings the diorama to life and adds a whole new level to the work generally.
Congratulations on a job well done.
Nige
OCT 12, 2006 - 04:07 AM
Yes Andy, you can build Dios in smaller scales :-) I just finished this one in 1/144 :-) It's only 11 x 14 inches.
DEC 01, 2006 - 02:08 AM
Copyright ©2021 by Chuck Shanley. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2006-10-09 00:00:00. Unique Reads: 9085
