Hi guys.
Yes its a year already!
Allen. The details for "Little Butch" are correct.
P-47C-5-RE
41-6410
QP-Y
Gilbert Ross
334th FS
4th FG
The decal sheet is dated July 1943.
This is about the time that the "Star And Bar" as opposed the star in the yellow circle was coming into use.
The belly tanks used briefly in July 1943 were the 200 Gall "Ferry Tanks"
These were only used for a short period (approx a month) before the P-47s were fitted with belly tank shackles in August 1943.
So for a pre August 1943 P-47C you would need to fill the area around the fusalage shackle parts on the kit.
As far as Im aware, nobody produces an AM ferry tank for a P47. If any manufacturers are reading this etc etc...
The 56th naturally couldnt resist adding some decoration to these ferry tanks.
If you wanted to depict "Little Butch" around August 1943, the 75 gallon drop tank would be suitable.(see LM-F photo above). The 108 gallon drop tanks came into use in November 1943 and were initially carried under the fusalage only.
Use of these tanks positioned on the underwing shackles comenced in early 1944 (Feb/March)
P-47C's were not fitted with the appropriate plumbing and never carried drop tanks on the wings.
Havent found a photo yet but I'll keep looking.
Chances are that around June/July 1943 your P-47 would have been fitted with a whip ariel.
Hope this helps
Thanks for the input on various kits everyone!
Nige
