And now folks, for another "Hey, you can't do that" moment... Brought to you by the kind people at Roden, and the Administrators of this Fabulous Site.
After I had finished the masking and spraying of the markings, I pondered how to go about making it look worn, dirty and well used. While pondering, I was fishing around in my bits and bobs drawers for something or other and came across some fine steel wool that had been left over from some other project.
(Hmmm, shame there is no "Light Bulb" Smiley below)...
Anyway, I attacked the tail plane that I had prepared in error with the steel wool on the streaked surface. Bingo! A worn and used look!
Then, holding my breath, and hoping desperately that this would not destroy weeks of good work, I attacked the whole build with the steel wool on all the streaked surfaces.
Then I set about cutting a couple of hundred strips of masking tape about 1.2mm wide... Then proceeded to apply these to all the surfaces that would have sported rib-tapes. The 1.2mm Might have been a tad wide, but I am looking for an effect here rather than an accurate represtentation of rib-tapes.
Then, thinning the left over paint that I had used to do the streaking even more, I pushed the pressure up as high as it would go on my compressor, pulled the amount of paint going through the brush back to its absolute minimum, and sprayed aver all the taped surfaces holding the airbrush at a distance of about 10-12mm from the surface of the plastic. I used the same thinned Olive Drab on the under surfaces as well. Then went over all the ridges where rib tapes were not to be found (ie, control surfaces, tail plane).
Here's what it looks like.
I think it will look fine under a coat of flat clear.
Hmmm... I take the attitude that if at the end it looks like a dogs breakfast, I can always strip it back and start again... I have used no decals afterall, so I only have to repaint.
Hugh
