Thanks for the info guys.
"apart for not smoothing the underlying paint with some fine (12000 grit) wet and dry"
Hi Allen. I believe that's exactly the reason. And after reading the instructions you posted it seems that the standard Alclad paints can be buffed with Micromesh. I'll probably do just that once I've finished with the Alclad.
Thanks for posting the link Ian. Lot's of helpful info at that site.
I've read your article a couple time now Nige. Glad you took the time to put it together. I particularly like the line: "Indeed, a comment often seen in the forums on Aeroscale goes along the lines of Ive tried a NMF before but never managed to finish one." Seems so familiar.
After another Saturday at the ol' hobby shop I came home and continued work on Fat Cat. Popped in a Band of Brothers DVD and started masking the fuselage, wings and cowl. I got ahead of myself when I stated that weathering was next. I almost forgot to spray various panels in different shades of Alclad. .
Skip ahead a couple hours and now she looks like a mess. Ready for some White Aluminum.
Here's the cowl, masked up and ready to go.
The White Aluminum was sprayed vertically on the fuselage and cowl panels. On the wing panels the Alclad was sprayed from front to back using quick strokes. The pressure was around 20 psi and the airbrush was held very close to the surface to create fine streaks in the finish. You can see some of the streaks in the next picture. Especially on the masking tape. Note that on the spine you can still see some preshading.
And now. The moment I was dreading and looking forward to all day. Removing all that sticky tape. Gasp.
Ask and you shall receive Nige.
Ta-daa! Not one little piece of paint came off.
Even though the canopy masks had been on for over a month they came off without a hitch.
Here's a closer look. Even over a flat finish it looks pretty good too me.
And the cowl again.
I couldn't resist.
Ah heck. Why not take her outside. You just can't beat natural light for photos.
I'm building an NMF model and I'm actually....having fun. Didn't expect that.
Gonna let her sit over night and maybe do some more spraying tomorrow.
-Matt
