Hi all!
Not much activity here, where is everybody?
Well, I have done some work on my Viggie;
After cutting the engines, I did some clean-up and test fitting with the new cans from Aires.
Fit is excellent and I discoverd that I have to glue the burners from the inside, but the exhausts can be left off and installed from the outside when painting is done!
Saves a lot of masking for sure!
But first I had to make some "filling" as I did not cut the kit-engines exactly in the same spot!
Here´s my old "plastic" useful once again!
Then it was a snap to glue the Aires burner tubes in place, and then close the aft section.
After that I glued the long under-fuselage "canoe" holding the camera bays.
Everything fitted very well and I have not used any filler, only a light sanding was needed.
Next was to install the main landing gears and I gave them brake lines made from a mellow 0.5mm soldering "wire".
The large covers fitted very well and was glued in the closed position.
Then came the wings, and now the build got in the "speed-mode";
As can be seen, a perfect and clean fit;
Then the intakes;
...and the nose;
Everything fitted perfectly with no need for any filler!
Beside the F-101B Voodoo, the sieze of the RA-5C can be appreciated;
From top, RA-5C, Phantom II, F-101 Voodoo
The Vigilante is a LARGE aircraft by every count!
Soon time for paint!
Cheers!
Stefan E
