Germany
KitMaker: 5,609 posts
AeroScale: 5,231 posts
Posted: Thursday, August 14, 2008 - 04:52 AM UTC
Hi Jean-Luc
that is too bad, but I will keep nagging
I am looking forward to see this finished!
cheers
Steffen
Moselle, France
KitMaker: 5,653 posts
AeroScale: 4,347 posts
Posted: Thursday, August 14, 2008 - 11:38 PM UTC
Hi Steffen!
I will kepp nagging
No Problem, you have the right to...
I finished the camouflage. Here is the painting sequence...
Then I masked the areas where the german markings where overpainted...
And finally the model received a coat of future...
The Siebell is now ready to receive the British roundels...
Germany
Posted: Thursday, August 14, 2008 - 11:50 PM UTC
Beautifully done, Captain!! .. I hope the Roundels will ruin the paintjob
.. well, not really
You could have corrected the "Miss pelling" in your quote, though. (my mind is a bit faster than the fingers)
Al the best
Steffen
Uusimaa, Finland
KitMaker: 2,845 posts
AeroScale: 1,564 posts
Posted: Friday, August 15, 2008 - 01:32 AM UTC
Superb job once again!
That preshading really hits the spot on this camo scheme.
On the markings, I personally don't have any objections to the British roundels, but I get the idea. It must look as weird as a Brewster Buffalo in US, British or Dutch markings to me.
California, United States
KitMaker: 817 posts
AeroScale: 729 posts
Posted: Friday, August 15, 2008 - 03:59 AM UTC
British markings? Say it ain't so, Ted! Keep it German and I'll dig the next ditch for you- promise! Seriously- this is a beautiful build- congrats!
[url]http://chukw.blogspot.com/[/url]
Germany
Posted: Friday, August 15, 2008 - 05:15 AM UTC
Moselle, France
Posted: Friday, August 15, 2008 - 07:03 AM UTC
Hi guys!
Indeed, the Siebel is now officially in British hands...
Don't expect to see the next update soon. I have to place all the small bits, do the panel lines, weathering etc... it will probably take some days.
Moselle, France
Posted: Thursday, August 21, 2008 - 10:23 PM UTC
Hi all!
Just a short update to show you that I'm currently fighting with the front glazings...
When I'm finished with this part of the build, it should no be too long before the model is finished.
Scotland, United Kingdom
KitMaker: 1,699 posts
AeroScale: 1,384 posts
Posted: Thursday, August 21, 2008 - 10:46 PM UTC
Battle on Jean-Luc. I'll be sad when this build is finished too, I've enjoyed following it.
Germany
Posted: Thursday, August 21, 2008 - 11:01 PM UTC
Hola Jean-Luc
I am always amazed how you make those dogs look like easy models. Really superior skills!!
I still bemoan that you did not use German markings on this .. nag nag
greets
Steffen
KitMaker: 817 posts
Posted: Saturday, August 23, 2008 - 04:44 AM UTC
I'm having flashbacks to my He111! Very nice, ted- very nice indeed-
chuk
Moselle, France
Posted: Tuesday, August 26, 2008 - 07:34 AM UTC
Hi all!
Time for another update. I promise it will be the last one before the model is finished.
I did the radar antennas with various rods and left over parts from a scrapped He 219...
I see the end of the tunnel!
Germany
Posted: Tuesday, August 26, 2008 - 07:58 AM UTC
Hi Jean-Luc
please check your refs again. IMO the dipoles have to be on one side if the mounts ...
all on the upper side in this case. Here is da link
http://www.warbirdphotographs.com/LCBW4/He219-A7-4.jpg for a better view.
Here is another one
http://www.luftarchiv.de/flugzeuge/junkers/ju88nacht.jpg greets
Steffen
Moselle, France
Posted: Tuesday, August 26, 2008 - 08:59 PM UTC
Hi Steffen!
Aaargh! Damn... I will change that. Thanks Steffen!
Germany
Posted: Tuesday, August 26, 2008 - 09:46 PM UTC
Hi Jean-Luc
Again:
Please check your references! ..... was this a German or a British "RADAR" my comment was made assuming it is a German FuG 220. .... you should have made a Geman machine
cheers
Steffen
Moselle, France
Posted: Wednesday, August 27, 2008 - 06:37 PM UTC
Hi Steffen!
According to the refs I have,this Siebel was equiped with a
German FuG 219 radar...
Germany
Posted: Wednesday, August 27, 2008 - 09:40 PM UTC
Hi Jean-Luc
o.k.
I tried to find a pic of that beast online without success. Hope you have a reference how it has to look. (one day I must buy that Bordfunkmeßgeräte book by Trenkle)
Well, at least I found some text:
FuG 218 “NEPTUN”, R3, J3, V/R, G/R
This set was developed during sumer of 1944 both by Siemens and FFO together, to substitute the SN-2 as the Allies discovered new countermeasures against the latter. It was a derivative of the FuG 217 from which it kept the name. Four versions were provided.
These versions of the “Neptun” had a range of 120 to 5000 m and operated with six fixed frequencies ranging from 158 to 187 mHz. The FuG 218 was mounted in a "X" support similar to the earlier SN-2 antennaes but smaller. The dipoles -of two different lenghts- were mounted on this "X" support which was installed on a single main mast mounted on the centerline of the nose of Ju 88 or Me 110. The support was niknamed Hirschgeweih (Stag's antlers) name also given to the big SN-2 antenna. The Neptun entered service during the last months of 1944 and featured also tail warning capabilities using a small curved mast with two horizontal elements all installed on the tip of the vertical fin. A version with four sets of three in-line vertical antennaes was fitted to some Fw 190 A-6 for “wilde Sau” operations. A further development increased the power of the G/R transmitter from 30 to 100 kW.
FuG 219 “WEILHEIM”
This was a further development of the “Neptun” carried out by Siemens. It operated with a 100 kW power at 172-188 mHz. Its range was supposed to be about 15000 m.
Source: The German Radar
So if you have a Weilheim mounted the forward dipoles should be a little bit shorter that the rear ones ... (?)
Steffen
Germany
Posted: Wednesday, August 27, 2008 - 10:15 PM UTC
Furthermore the Neptun dipoles are evenly thick over the whole length and go through the mounts and are not attched sideways as the late Lichtenstein FuG's
All assuming the Weilheim would have the same appearance as the Neptun....
it is the detail that bites you in the a.... had that all too often with my modelling projects.
viele Grüße
Steffen
Moselle, France
Posted: Wednesday, August 27, 2008 - 10:54 PM UTC
Germany
Posted: Wednesday, August 27, 2008 - 11:09 PM UTC
I plan to present the model at a German show in october. I wonder how many people will notice that the radar is not completely right...
Hi Jean-Luc
looks really great! If only I could do my models as good
As for the "radar" .. all who have read this thread
and some experts or you say it was equipped with a Lichtenstein SN2 for test purposes
all the best
Steffen
Merlin
Senior Editor
#017
United Kingdom
KitMaker: 17,582 posts
AeroScale: 12,795 posts
Posted: Wednesday, August 27, 2008 - 11:27 PM UTC
Hi Jean-Luc
Wonderful work - as usual! You never know - a model of such quality might actually start a vacuform revival among our readers!
BEWARE OF THE FEW...
Germany
Posted: Wednesday, August 27, 2008 - 11:37 PM UTC
Hi Rowan
while I agree with most of what you wrote. I cannot on this
... a model of such quality might actually start a vacuform revival among our readers!
lets rather hope MPM Group will shoot out a new IM model in 1/48 in a not too distant future ...
OTOH I just checked the stash I have here ( about 1/4-1/2 of what I have in total) and there are a lot of beautiful (already started) models to do. ... just fondled that Hasegawa Mc 202 with the FoM set again .. engine already sawed open ...
focus, focus, focus, focus, ... do not start another project
cheers
Steffen
Merlin
Senior Editor
#017
United Kingdom
Posted: Wednesday, August 27, 2008 - 11:43 PM UTC
Hi Steffen
Well I love vacuforms! Inspired by Jean-Luc, I couldn't resist dragging one of my old 1/48 scale Fw 58 Weihes out of the stash. The only trouble is - I haven't got room (or time) to build it at the moment!
Germany
Posted: Wednesday, August 27, 2008 - 11:55 PM UTC
Here is another inspiration
Focke Wulf Weihe by Swanny. He has a soft spot for Romanian aircraft (or a buyer who pays good for it).
cheers
Steffen
Merlin
Senior Editor
#017
United Kingdom
Posted: Thursday, August 28, 2008 - 12:33 AM UTC
Hi Steffen
Very nice! But, as much as it pained me, the Weihe had to go firmly back into the stash - another 15 years or so waiting won't do it any harm! It's like a good wine, maturing nicely...
