Is there any evidence whether the underwing crosses on this Dr.1 were originally on a white field (which was then maybe overpainted, along with the others), or applied directly on the undersurface colour?
Hi again Stephen Is there any evidence whether the underwing crosses on this Dr.1 were originally on a white field (which was then maybe overpainted, along with the others), or applied directly on the undersurface colour? All the best Rowan![]()
All undersurface - lower wing cross fields came from the factory were clear doped linen. Most of these were overpainted light blue at the depot just like the olive on the upper surface cross fields.
Thanks Rowan, sounds deceptively straightforward
Hey Carl;
Think of it this way. White fields of the crosses were applied at the factory level. Then shortly after arrival at the depot the white fields were overpainted olive green just leaving a 10cm white border around the crosses. Then possibly the wing and fuselage was partially overpainted yellow at the unit level. Note, most of this would have been accomplished before the machine was finally assembled for duty at the unit level.
Can I ask, what was the method you used for making the neat border line along the bottom edge of the fuselage and the outline of the elevator?
