General Aircraft
Aircraft Trivia Quiz 2 (Join In)
warreni
KitMaker: 5,926 posts
AeroScale: 2,201 posts
Posted: Friday, May 27, 2011 - 01:15 PM UTC
I'll just leave you two too it..
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Sunday, May 29, 2011 - 08:06 PM UTC
Thank you, Jessie.
On a war time Imperial German Zeppelin, lighting up would surely send you to court marshal, faster you could say “cigarette”. Except one spot on the airship, where smoking was allowed. Which one??
warreni
Posted: Sunday, May 29, 2011 - 08:33 PM UTC
I am guessing here but could it have been on the bridge or in the observation car?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Sunday, May 29, 2011 - 08:49 PM UTC
That's it: observation car. Thanks Warren.
Bring it on.
Bring it on.
warreni
Posted: Sunday, May 29, 2011 - 09:34 PM UTC
Interesting fact, the observation car hung from the zeppelin on a 750 or 1000metre long cable of stainless steel with a rubber insulated core of copper wire which carried telephone signals from the car to the zeppelin.
OK, where is the engine oil-pressure transmitter located in a de Havilland Canada Caribou?
jaypee
KitMaker: 1,699 posts
AeroScale: 1,384 posts
Posted: Sunday, May 29, 2011 - 09:39 PM UTC
The pressurised smoking room of course!! Well that was the hindenberg.
EDIT: That was to the previus question of cource
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Sunday, May 29, 2011 - 10:25 PM UTC
That's definitely a Jessica thing so I leave it up to her.
Blueheeler
KitMaker: 347 posts
AeroScale: 223 posts
Posted: Sunday, May 29, 2011 - 11:45 PM UTC
Main engine panel in the cockpit?
No idea....
Nick.
No idea....
Nick.
jaypee
Posted: Monday, May 30, 2011 - 04:13 AM UTC
In the cargo compartment? Ready to pump more oil into the r2000s as it squirts out over the northern tundra?
warreni
Posted: Monday, May 30, 2011 - 10:15 AM UTC
No to all so far.. Think about the system as a whole...
Jessie_C
Posted: Monday, May 30, 2011 - 11:07 AM UTC
Perhaps in the oil tanks? It makse sense if the entire system was maintained at the same pressure...
warreni
Posted: Monday, May 30, 2011 - 04:06 PM UTC
No.. pressure is taken from the engine...
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, May 30, 2011 - 07:30 PM UTC
My guess is that there is no oil pressure gauge. I think that there is just a low and high pressure indication light for each engine on the lower end of the main engine panel.
Removed by original poster on 05/31/11 - 06:31:10 (GMT).
Removed by original poster on 05/31/11 - 06:32:46 (GMT).
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, May 30, 2011 - 07:37 PM UTC
jaypee
Posted: Monday, May 30, 2011 - 07:45 PM UTC
Is it part of the feathering gear of the prop?
warreni
Posted: Monday, May 30, 2011 - 08:56 PM UTC
It definitely has one oil pressure gauge for each engine.. I should know as I worked on them as an Instrument Fitter for a few years..
Now they are sitting at Oakey rotting away..
jaypee
Posted: Monday, May 30, 2011 - 09:53 PM UTC
is it the gauge or the sender we are looking for? I thought the sender might be part of the feathering system, not the gauge, that would just be stupid.
warreni
Posted: Monday, May 30, 2011 - 10:15 PM UTC
That is definitely a Caribou instrument panel Antonatos, but the RAAF ones were a little different and painted black, not grey.
The transmitter, or sender. It would make sense that it is not too far from the engine. Less chance of a leak...
It was fun changing the transmitter as you had to lockwire the bolts and screws totally by feel as you could not see the bolts and screws you were lockwiring. Joy.
The prop-feathering system was done using a differential switch mounted in the roof of the cabin between the wings. Pressure was applied to both sides of the switch and if the propeller wash of either of the engines decreased below a certain point the switch automatically feathered the prop on the sick engine.
Amazing what you can remember after 30 years..
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, May 30, 2011 - 10:27 PM UTC
Aha !!! Gatsa..
From the flight manual:
" The oil pressure gage is an electrically operated autosyn gage witch registers oil pressure at the rear engine case”. The schematic attached, shows two oil pressure gauges in the central engine panel lower line.
The oil pressure transmitter is indicated in the engine nacelle right underneath the oil tank drain.
Now since you asked and I can’t locate the gauges in the picture above I’d say the latter.
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, May 30, 2011 - 10:31 PM UTC
On a second glance, it’s located sideways, inner side of the drain.
warreni
Posted: Monday, May 30, 2011 - 10:34 PM UTC
I think that is close enough.. It and two other pressure transmitters were located in the main wheel well on the rear of the firewall. You had to stand up the whole time while you were changing them and have your arms above your head for ages. Lovely job..
Congratulations Antonatos. Over to you.
jaypee
Posted: Monday, May 30, 2011 - 10:35 PM UTC
Wow is that a proper transmitter then plumbed up to the cockpit gauge, not an electrical transducer?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, May 30, 2011 - 10:39 PM UTC
Tell me something Warren. Did the above mentioned oil pressure gauges on the main engine pannel exist or no ??
