After fiddling with pulleys in the wing windows, I found the first photo today, and I see that only half of the pulley was visible in the window- the other half being mounted in the spar itself. Too late to change mine now (and they are so tiny on 1% of people would notice even if they knew how they should be).
I've been considering how to shade the wings. I could do complex pre-shading, but if I do too thick a coat over it, there would be no going back. One confusing thing is that in some photos the rib tapes look dark (eg. when back-lit strongly, I guess), but most of the time, they look lighter than the surrounding cloth. Some photos show the spars inside as a shadow, sometimes a pale strip, almost as clear as the rib tapes. I have seen a very nice photo of how the light from the pulley window shines into the wing, illuminating the under surface:
I have planned out how I'll do the shading- all will be post-shading. I'll be using water colour paint, so any disasters can be easily removed. I may spray a thin varnish coat between the shading and the highlight mists, so I can wipe off the highlights if they go wrong without having to re-do the shading as well.
The plan for the upper wing surfaces:
And for the lower:
(images have been automatically scaled by the forum software, right click and 'open image in new window' to see full size)
