Hi everybody
Back again after a bit of a slow time, doing things other than modeling.
This time I’ve been concentrating on what I consider one of the more tedious tasks of building (the other is drilling rigging holes). So here’s a resumé of a lot of fun, filling, filing and fiddling about.
There has also been some construction... The decking covering the guns had to be scratch built, and ofcourse the nosejob itself... It’s all taken a bit of extra time, as I’m also doing my DI in paralell with the OEFFAG, keeping an even pace with the progress on both.
Radiator: The B.A. kit supplies this as a solid resin block, to be sunk through the wing after cutting a rectangular hole, much like the real thing. As the radiator is quite different from the Albatros OAW version, I had no choice, but to follow the B.A. instructions on this one.
After measuring out the location, I taped the borders of what was to be cut out... Then drilled as many holes as I could, being careful to stay inside the taped area on both sides of the wing. The hole was cut using scalpel and a small Tamiya saw, keeping it quite tight to avoid too much filling later on.
After some final filing and fitting, the radiator squeezed in quite snuggly.
Nose: The nose is not quite the right shape heighwise – so apart from adapting it for the its airframe I’m having to make the whole thing a bit taller... Hope my plan works, right now it all looks a bit strange
Using palsticard –trying to reshape things in the front – there will be lots fun, filling and filing here as well. Hope i know what I’m doing here – we’ll see...
Tail: The OEFFAG tail is a bit different in shape, looing more like the later DV.
A plastic rod was bent into shape, creating the outline. This was then filled in with plastic sheet cut to shape.
Body: Nice as the Roden detail on the fuselage is, it’s not appropriate for this DIII type, so... more filling and filing, first removing the louvres and side doors on the nose. They will be replaced later with PE bits.
There’s also the need for some rescribing of panel lines. Althogh the shape of the Austrian DIII is very similar to the German counterpart, some panels are different.
Decking: Here I used as much of the upperdecking as I could from the Roden kit, shaping the access ports with thin plasicard, then... You guessed it, fun filling and filing... The doors were made from PE bits and plastic strips.
To get a clue to how I was doing, I sprayed the panel – Yup, more filling, and filing was needed...
That’s it for now, still some more to do before I can do the scribing and detailing, then finally a basecoat, before the fun really begins...
Til nex time – Thank You for watching. Any comments would be most welcome.
