Here's the kit pre-build. The sprues seem kinda chunky (almost like a level 2 Academy kit. Don't ask me why I know this...), though there isn't much flash and the detail looks pretty nice. Wings and fuselage in dark plastic, engine, arms, and other small pieces in lighter plastic. I've heard some "wonderful" things about the decal sheets...can't wait to work with them...
I know I took a picture of the engine alone, but I can't seem to find it. Anyway, the engine made me so happy to build. Simple construction, abundant detail, and everything fit almost perfectly! It really gave me high hopes for this kit! Then the misery began. First, I noticed that there were holes in the cowlings, but there was an extra hole in the right cowling. I had read about Roden skimping on styrene and resulting in holes in parts or even nonexistent parts, so I figured I must've gotten a kit they got lazy with.
The light sprues were near perfect thickness if pressed slightly with pliers. I sculpted a sprue, glued it in the hole, then sanded and carved it flush with the side. To make sure it worked okay, I painted it (pictured here). Not a bad repair, I figured, and I moved on.
Then I found out that that extra hole is for the exhaust pipes. Great. So out came the rotary tool. Luckily this was an easy fix. Just kinda frustrating. So then I moved on to encase the engine. I must've spent over an hour trying to reshape, manipulate, finagle, and finally brutally force these five pieces into place. And even then the best result I could manage would probably be rated "atrocious" on a scale of 1 to 10. The pieces simply didn't fit, like the classic square-peg-round-hole problem. I should also mention that my tube of putty had dried up. Perfect timing, no? So here I am with a dysfunctional engine housing hiding a beautiful engine. I'll be going back tomorrow to try to clean up the glue-filled canyons a little bit, but I'm honestly not expecting to make much more progress on this section.
If anyone else has built this kit and can advise me as to what other little joys I can expect, please let me know! In the meantime, I'll keep pushing along with this kit. Hopefully, the worst is FAR behind me now...
