Lance, ref your cowl/coaming issues, There appears there was a lip where the metal coaming sat over the fuselage side, maybe an easy fix is to add this and sand the edge of the coaming join smooth, a less damaging repair route?
Thes things have a way of biting you in the bum when you are getting a little too comfortable for sure.
Keith
Keith,
Brilliant idea! I checked a bunch of photos again and you are correct. I believe adding the "lip" will solve the issues from the aft edge at the split in the leather coaming up to the wing root. I can then shave down the top portion of the cowling over the wing assembly and it should be perfect. The photo I'm referring to specifically is #34/3 on pg. 76 of the Windsock Fokker DR.1 Jagdstaffeln Special, 146/17 with August Delling in the cockpit. There is a pronounced gap between the upper metal coaming and the wing and the lip you mention stands out clearly.
I had actually just sat down and picked up my razor saw when I thought I'd check back here first just on the slim chance that someone had replied with some sage advice........... Thanks for looking and the afore mentioned suggestion. I'm on it and will report back with results soon. That old adage about a second set of eyes is sooooo true!
Lance
