Having recently admired the Mitsubishi Claude build log published recently I started keeping some basic pics and note on the Special Hobbies Polikarpov I-15 "Chaika" (or in Spain "Chato"). Designed slightly after the I-16 monoplane and flown in 1934 it was produced concurrently with the I-16 and used in the front line until 1941. Highly maneuverable and fairly fast for a biplane the aircraft was effective until it encountered modern monoplanes. The kit is attractively boxed and is a multi-media kit with injected, resin and pe parts. These first pics cover the fuselage assembly and kit parts. I intend to finish the model in Alclad Polished Aluminium and Vallejo metallic Silver and rigging will be using nylon monofilament thread. The undercarriage, interplane struts and rudder will be red. This is one of the colour schemes on the kit.
Pretty nice injected parts with no pin marks and reasonable detail
Resin parts
Resin engine parts look good
Base coat of paint on cockpit resin and pe parts
Assembled cockpit, instrument panel is nicely done, resin base, acetate instruments and pe panel sandwiched together.
Firewall and nose does not fit well, sand and fill ing required here, especially as this part will be alclad covered
Bottom seam, the only one that did not fit well.
More when I get the photos uploaded
