1:32 Revell P-51B "BIG MAC Junior"
FlorinM
KitMaker: 385 posts
AeroScale: 173 posts
Posted: Tuesday, November 04, 2014 - 11:34 PM UTC
The part of this build that made me nervous is no longer an issue. The Aires gear bay, designed for a completely different wing profile, now fits the laminar flow wing, wasn't easy, with resin and plastic being paper thin in places. This is how a dry fit test looks like:
Posted: Wednesday, November 05, 2014 - 01:47 AM UTC
Florin,
Outstanding adaption of the Aires wheel wells. I'm sure it was no easy task.
FlorinM
KitMaker: 385 posts
Posted: Wednesday, November 05, 2014 - 03:46 AM UTC
Had to pull it through, the alternative would have been to scratch build the whole bay, not impossible, but time consuming. One thing is sure, it's a cakewalk from now on.
FlorinM
KitMaker: 385 posts
Posted: Sunday, November 09, 2014 - 12:44 AM UTC
Correcting a minor inaccuracy - the landing flaps, being too narrow, outboard by 2 millimeters and inboard by 3mm were removed and will be replaced:
FlorinM
KitMaker: 385 posts
Posted: Tuesday, November 11, 2014 - 06:45 PM UTC
Perfect fit, the transplant is a success! This is how a Trumpeter windshield looks when fitted to the Revell fuselage.
A while back I manged to swap my very last 1:48th kits (working only large scale now) for a Trumpeter Mustang. It's inaccurate as hell, but the windshield and main landing gear legs are better than their ancient counterparts. These parts were kept and will be used on the Revell kit, while the rest of the kit was unceremoniously disposed of.
Posted: Tuesday, November 11, 2014 - 09:06 PM UTC
Florin,
Nice conversion with the glass. It looks quite good.
FlorinM
KitMaker: 385 posts
Posted: Wednesday, November 12, 2014 - 04:16 PM UTC
Starting to look like a Mustang
FlorinM
KitMaker: 385 posts
Posted: Thursday, November 13, 2014 - 05:01 PM UTC
A new pair of flaps was fabricated using flaps found in the spare parts box. The top half shall be engraved on the wing halves. The narrow ones represented in the kit were filled by using a strip of Evergreen.
Note that the outline shape of the wing overlaps the plans perfectly
Posted: Friday, November 14, 2014 - 03:52 AM UTC
Florin,
Those flaps are absolutely perfect in scale.
FlorinM
KitMaker: 385 posts
Posted: Thursday, November 27, 2014 - 03:56 PM UTC
Many thanks for your constant companionship, Joel!
The landing flaps have received their rivet patterns:
Posted: Friday, November 28, 2014 - 07:19 PM UTC
Florin,
You're more then welcome.
Are you using the Archer rivets? Never used them myself, but I really need to.
FlorinM
KitMaker: 385 posts
Posted: Friday, November 28, 2014 - 09:19 PM UTC
Apparent rivet heads would be inaccurate, the patterns were done by using a riveting wheel, are recessed and temporarily filled with graphite so that they are more visible. Other than a panel on the belly (you will see that soon enough), the Mustang had a very clean surface, with flush rivets.
Posted: Friday, November 28, 2014 - 09:57 PM UTC
Apparent rivet heads would be inaccurate, the patterns were done by using a riveting wheel, are recessed and temporarily filled with graphite so that they are more visible. Other than a panel on the belly (you will see that pretty soon), the Mustang had a very clean surface, with flush rivets.
Florin,
I'm really impressed that you got the rivet lines that straight with a wheel.
Espeically the wings rivets and seams were filled then painted with Aluminum dope for the smoothest surface possible.
FlorinM
KitMaker: 385 posts
Posted: Wednesday, December 10, 2014 - 06:12 PM UTC
Need to close the fuselage. The Aires cockpit floor has bent like a banana, so a new one was made out of styrene. This is a test fit of the new layout:
FlorinM
KitMaker: 385 posts
Posted: Thursday, December 11, 2014 - 03:27 PM UTC
These are the ribs that might be visible through the quarter panels.
Posted: Thursday, December 11, 2014 - 11:25 PM UTC
Florin,
The cockpit floor looks quite nice. But those ribs are really well done.
chris1
KitMaker: 949 posts
AeroScale: 493 posts
Posted: Friday, December 12, 2014 - 02:16 AM UTC
Hi Florin,
Just found your build. (I've been out of the loop for a while)
She's looking really good.
I myself prefer the B to the D particularly if it has a Malcolm canopy, just looks sexier somehow.
I'll be following along.
Chris
Chris
greif8
KitMaker: 673 posts
AeroScale: 492 posts
Posted: Friday, December 12, 2014 - 01:49 PM UTC
Hi Florin, that's a sweet build you've got going on. Your scratch building is first rate.
FlorinM
KitMaker: 385 posts
Posted: Friday, December 12, 2014 - 10:33 PM UTC
Thanks, guys, hope you enjoy this as much as I have fun building it!
FlorinM
KitMaker: 385 posts
Posted: Thursday, December 25, 2014 - 01:12 PM UTC
Just like on the real aircraft, fitted with the "Malcolm" hood, a right-angled triangle was glued on top of the cockpit sides. One of its sides has 2.1 centimeters, while the other measures 0.5 millimeters.
This is important because it gives the correct angle for the guide rails on which the "Malcolm" hood slides.
FlorinM
KitMaker: 385 posts
Posted: Tuesday, December 30, 2014 - 03:00 PM UTC
The armored glass behind the windshield was replicated from clear plastic and thick aluminum foil.
norherman
KitMaker: 20 posts
AeroScale: 19 posts
Posted: Friday, January 02, 2015 - 06:10 PM UTC
Need to close the fuselage. The Aires cockpit floor has bent like a banana, so a new one was made out of styrene. this is a test fit of the new layout:
norherman
KitMaker: 20 posts
AeroScale: 19 posts
Posted: Friday, January 02, 2015 - 06:13 PM UTC
Didn't the B and C models come without the wood floor. The floor was the wing. D models and up had wood floors. Dave
FlorinM
KitMaker: 385 posts
Posted: Friday, January 02, 2015 - 08:46 PM UTC
Check your references carefully, Dave! Only the Allison powered versions of the Mustang (P-51 P-51 A and the A-36) had the metal floor sections that were the top of the wings. The B, C, and D versions had wooden cockpit floors.
FlorinM
KitMaker: 385 posts
Posted: Sunday, January 04, 2015 - 06:03 PM UTC
Yet another tiny update, this time it's the oxygen hose made from stretched sprue and sewing thread wrapped around it
