Florin,
I must say that your battery really looks quite good.
1:32 Revell P-51B "BIG MAC Junior"
Posted: Sunday, February 08, 2015 - 08:43 PM UTC
FlorinM
KitMaker: 385 posts
AeroScale: 173 posts
Posted: Monday, February 09, 2015 - 11:31 AM UTC
It will barely be visible, but at least it's there!
FlorinM
KitMaker: 385 posts
Posted: Thursday, February 12, 2015 - 12:48 PM UTC
Three millimeters were added to the fuselage fuel tank, its length being 3 millimeters off (36 mm compared to the correct 39).
The floor section is gone because it was inaccurate, a new one will be built in its stead.
FlorinM
KitMaker: 385 posts
Posted: Friday, February 13, 2015 - 12:02 PM UTC
Work at the new floor sections has made another correction imperative: the console on the left cockpit wall was suspended 1.5 millimeters above the cockpit floor when it should have been on it (in the real aircraft there are cutouts in the left floor section where the console sits).
It was duly removed and will be relocated to its accurate position.
FlorinM
KitMaker: 385 posts
Posted: Wednesday, February 18, 2015 - 07:54 PM UTC
The new floor is a two part affair: on top is the part that will receive the "plywood" sections and under it is the top of the wing
FlorinM
KitMaker: 385 posts
Posted: Saturday, February 21, 2015 - 01:01 PM UTC
The console has been lowered to where it should have been in the first place...
Posted: Saturday, February 21, 2015 - 10:34 PM UTC
Florin,
Truly outstanding work on those cockpit sidewalls. The end results will be worth all your efforts.
FlorinM
KitMaker: 385 posts
Posted: Sunday, February 22, 2015 - 03:00 AM UTC
Thank you for the trust placed in me, hope my Mustang won't disappoint!
Posted: Sunday, February 22, 2015 - 04:17 AM UTC
Florin,
From the level of detailed work you've displayed in this thread. I'm quite confident that it's going to be an award winning model.
FlorinM
KitMaker: 385 posts
Posted: Sunday, March 01, 2015 - 05:16 PM UTC
Must confess, I build for myself and do not seek awards.
That being said, the Mustang has a new, more accurate floor section, and as you can see it is quite different from the previous attempts. The rough look of the black paint on the floor is deliberate, in real life the paint was mixed with quartz sand for an anti-slip effect.
Posted: Sunday, March 01, 2015 - 06:35 PM UTC
Florin,
Nicely done floor effect. One the seat, sidewalls, and details are added, it will really be a major improvement over the original kit "pit".
FlorinM
KitMaker: 385 posts
Posted: Monday, March 02, 2015 - 01:31 AM UTC
Can't wait to close the fuselage halves together, but there still is much to do
greif8
KitMaker: 673 posts
AeroScale: 492 posts
Posted: Monday, March 02, 2015 - 11:53 AM UTC
Superb scratch building and super detailing Florin. Your build is turning out to be a very accurate scale representation of the real thing.
Ernest
Ernest
FlorinM
KitMaker: 385 posts
Posted: Monday, March 02, 2015 - 02:28 PM UTC
As much as possible. The fun is both in doing the research and then in applying the knowledge in scale.
FlorinM
KitMaker: 385 posts
Posted: Monday, April 27, 2015 - 12:43 PM UTC
The floor/top of the wing fuel gauges:
Posted: Monday, April 27, 2015 - 05:40 PM UTC
Florin,
I'm really impressed with the level of detail you're achieving. Those 4 fuel tank gauges on the floor would honestly be something that I would have over looked.
FlorinM
KitMaker: 385 posts
Posted: Monday, April 27, 2015 - 06:26 PM UTC
There are only two fuel gauges, the ones that can be seen through the holes. The knob immediately to the left of the control column is the cold air control, while the one behind the right fuel gauge is for the cockpit warm air. And yes, I know, I'm insane!
Posted: Tuesday, April 28, 2015 - 03:12 AM UTC
Florin,
Thanks for the clarification. In 1/48 scale at best they would be just a hole and a raised piece of plastic.
FlorinM
KitMaker: 385 posts
Posted: Tuesday, April 28, 2015 - 11:36 AM UTC
The Aires cockpit for the Trumpeter P-51B was originally designed for the Hobbycraft Allison powered Mustangs and is a botched attempt to render a "B" cockpit.
Hopefully this is the last correction and it is trivial, it concerns bringing the instrument panel to P-51 B standards by adding a rectangular piece of paper 2.5 by 6 millimeters with 6 holes in it. The pieces of wire for the switches will be the final touch. In real life these switches would activate the guns and the offensive payload.
FlorinM
KitMaker: 385 posts
Posted: Tuesday, April 28, 2015 - 06:35 PM UTC
And this is the instrument panel with some paint on
FlorinM
KitMaker: 385 posts
Posted: Thursday, April 30, 2015 - 08:31 PM UTC
Surface control lock, a tiny part that comes in front of the control column:
Posted: Thursday, April 30, 2015 - 11:15 PM UTC
Florin,
The IP looks as real as it can get without being real. I'm more then just impressed.
FlorinM
KitMaker: 385 posts
Posted: Thursday, April 30, 2015 - 11:23 PM UTC
Not satisfied with the way the picture turned up, lighting was far from ideal, the instrument panel looks better in real life.
Posted: Saturday, May 02, 2015 - 03:43 AM UTC
Florin,
Now I'm really impressed, as I thought it looks quite good in that picture.
FlorinM
KitMaker: 385 posts
Posted: Saturday, May 02, 2015 - 10:03 AM UTC
Thank you for your constant companionship, Joel, I really appreciate it! Without you this build blog would be nothing more than a monologue...
