Work has started in earnest on the stations, loads out, and the drop tanks. GWH has done a excellent job of molding raised wielded seam lines on the drop tanks.
Unfortunately, after I glued the tank halves together, some sanding was necessary to remove the Extra Thin glue/plastic seam lines. Now I'm not exactly the most careful modeler when it comes to sanding, so I ended up removing four sections of the wield lines, 2 from the front wield and 2 from the rear wield on all 3 drop tanks.
So now came the question on how to repair my screw up. At 1st I thought that some stretched sprue would do nicely, but after several attempts, I just didn't like the overall look, so I removed all the pieces of stretched sprue, resanded, and polished. Next came the old standby of tape and putty, so I tried Green Stuff. I just couldn't get it to lay down a nice consistent bead, so I thought about thinning it with Lacquer Thinner or Extra Thin. Neither option really appealed to me as I didn't want a smooth finish, and that's what I usually get with thinned out Green Stuff. My last option was Vallejo's white acrylic putty. I use it all the time to fill small scratches and seams, and this repair falls into that category if you stretch the concept enough. So I cut small strips of blue painters tape and carefully laid them along each side of the wield seam where the repair was needed.
Then I applied a rough bead of Vallejo white putty
Then removed the tape before it had set up
the repaired seams looked pretty good to me
So I went ahead and repaired the other two drop tanks. I gave it a day to dry, then primed the tanks with Mr.Primer Surfacer 1,000, gave that over night to dry and cure, then airbrushed on Model Master FS 36375 Light Ghost Gray. The final results looks pretty decent to me.
This drop tank trick comes in just on time for my Skyray
thanks
