As I continued with the confines of the cockpit, the molded rudder pedals look pretty nice, but the foot straps must scale out to more then a foot.
So I decided that even I could do better. 1st step was to cut off the existing straps.
Once painted, I made new straps out of thin strips of masking tape then painted them with Tamiya Earth.
Good enough for being buried down in the bottom of the pitand under the IP.
The yoke is a piece unit and looks the part. I decided to add the two electrical wires from the MG trigger switches. then used masking tape once again to duplicate the straps holding them position.
They're certainly a little over scale but it's the best I can do.
There are two main wing spars that should be painted Aluminum not British Interior Green, so they were primed and then painted with Alcad 2 #101 flat Aluminum along with all the other various parts of the most complete tubular pit I've built in a long time. Airfix did a fantastic job in design and engineering, as everything fits perfectly with no need for any filler, or sanding/filing other then general parts clean up. I did vary from the instruction steps by 1st gluing in the rudder, Yoke, and heel plate floor, then I glued into position the heel plates. For me it was easier this way. Here's the cockpit tubing with only the Port side tubing and support glued to each other. the Starboard tubing is just dry fitted for support and alignment. Not installed yet is the yoke nor rudder pedals as I still need to add the decal for the top of the compass.
Finally I gave each fuselage half a coat of my mix of British Interior Green so I can start to add all the little details
