Russell! Thanks! I use pigments for the exhaust traces, my favourite is simply MiG's "Smoke". I find that these "real" pigments have a slightly better "bite" into the base paint than ground pastels that tend to slip off. On the other hand, I often use pastels to add tone to the basic trace, they also come in handy if I want a fainter trace.
Torsten! Canopy was trimmed down, re-masked and re-painted. I ended up with another problem though: it was difficult to fix in place... I used UV-glue and re-did it three times but the glue joint can still be seen from the outside and it is also a bit lopsided. I'll leave it as it is for the time being, an alternative could be taking it off again and add some very thin rails to the lower edges so that I could actually use the grooves in the fuselage. Anyway, I'm out of patience right now so Hurricane is finished, at least for now
Jessie! Do you have economic interests in the clear decal film business (must be a good way of getting rich
)? This comes up every now and then and I'm still not getting along with the decal strips... I think I have promised you that I should try it again but this time I simply forgot it, looking at photos of real Hurricane canopies the metal is extremely thin and flimsy looking so decal strips would probably be the perfect way of simulating them! Next time! I promise
On to the photos:
Muddy... I'll revisit this theme in the future!
Together with older sibling Mk I...
...that I built
a year ago!
Time to retire the avatar...
...and move this one to
the collectionThanks for following and all your encouragement!
Magnus
