Well I finally got it finished, although it has taken me longer than I would have liked this is about the quickest that I have built anything, so I, for one, am quite pleased. Although it is not perfect, by a long way, I’m happy with the way it has turned out, as it was always going to be a case of “flattening the learning curve” on my first WW I subject. My biggest problem has really been with the control cables. As I said previously my preferred medium, invisible mending thread just wouldn’t stick with CA, so I tried with 2thou stainless wire. CA glued this with no problem but it didn’t look right. The solution was stretched sprue, but this caused a couple of problems, as you will see from my last post, but my problems didn’t end there. I used 2 lengths, on each forward fuselage side; to represent the aileron control wires. I was not entirely happy with how they looked, the 2 together just looked like 1 thicker cable, from most angles. I decided that they were OK however and continued with the wing struts. Invisible thread may have been better for the aileron control wires and these had been fitted into the top wing, before it was glued onto the “N” struts. When I tried to feed them into the holes, that I had previously drill into the forward fuselage, they pulled out of the top wing (I had secured them with CA!). With the top wing already secured I decided to use stretch sprue.
I test fitted the “V” cabane struts and found that the wing needed to move about .25mm one way. When I did this the aileron control wires were pulled, once again, out of there position (this time they had been secured with PVA), lesson learnt, position wing before attaching both ends of control wires.
I had few issues with the struts apart from the fact that I found it a little awkward and next time I shall have the model set at eye level. The one thing that I am really unhappy about is my painting of the wood effect on the propeller. I have tried to be far too ambitious and the colours are all wrong. All is not lost though, as I will strip off the paint and have another go. I have called it finished as is; otherwise it would be another week before I finish. I also think that the weathering, on the tail surfaces is too heavy. This is due to the fact that I masked off the ribs, after the initial coat of blue, so when the weathering spray was applied these ribs were just too light. I, therefore, went back and sprayed more dark earth on the entire surface, which was too much for areas already done. It is probable, however, that the tail surfaces did get muckier, they are close to the ground and they get the “last” of the dirty air, which is how I see it.
Last pics then:
Not having any Leggo I used these off cuts of MDF to check the “N” strut alignment
Top wing fitted, you can see the invisible thread “aileron control wires” before I ragged them out
Finished pics:
Mal
