Wayne
Sand filter looks very good. I agree that once everything is painted it won;t stick out like canine test..... the proverbial :-) .
I'm back from my 3 weeks leave and spent the day doing all the odd jobs required after such an absence - mowing etc. I don't start work again until Tuesday (that was planned) so 2 days of Tomahawk should see some painting done - well priming anyway.
The wings were glued before I left so they need sanding. A quick test fit of the wings - fuselage joint looks as thjough it will be fairly clean with only minimal filler required. I do agree with 1 review I read of this kit - and that is that the tail is toylike. the way it fits together allows the rudder to move - but the fit is so loose that it just flaps - and I couldn't see any way to make the fit tighter as I was putting it all together. So there is a chance (damn big one at that) that some superglue will magically appear in the join and fix the rudder in place. Ailerons just have pins and can't be made moveable - so no problems there.
I am not too sure about the undercarriage, i think that it may not be strong enough so I am thinking of using some brass rod to brace it.
Once I clear the 350 pics off the card in my camera I will take some updated pics.
Brian
