Not much activity here latley!
Now I have made some progress with the little MB.
Cockpit Is completed, painted, worn and "washed";
Yes, I have made a small piece of plasticard to cover the hole in the headrest!
The location for the cockpit tub in the fuselage side was poor to say It kindly!
I had to make a good "educated" guess, but had to support it from underneath anyway;
A large fishing weight was placed in the nose secton, as this Is a dead sure tailsitter and needs much weight to keep the nosewheel on the ground!
Fuselage halves fitted very good and lined up perfectly with the cockpit back bulkhead.
I had test-fitted the wing-to-fuselage joint earlier, and the fit here was very good then, but now I got this;
Oooops....
The wing assembly would not go down as the cockpit tub was too deep!
The solution was as easy as It was brutal, I sawed off a 2x2mm section from the rear bottom end of the cockpit tub. (Can´t be seen from the inside anyway!)
Now the fit was much, much better!
Nigh on perfect!
The tailplanes went on a snap, perfect fit here.
Even if this kit looked simple first, It keeps you on your toes!
Looks can be very decieving!
Cheers!
Stefan E
