Hello everyone,
Wow! Just under two hours to go! Jesper thank you for the compliment. Also, A big thank you to Bryan4010 for his nice Sea Harrier. Especially being his second aircraft model in two years! It is members like you that make these builds a cut above! I have already handed out ribbons and I will add any other entries that get completed by midnight tonight. I will submit a summary of our activities in the next few days so stay tuned. With that I have finished my third and final entry for the campaign. I have never built a PM models kit. They’re made in Turkey and I thought I would share my adventure in more detail with all of you in case you think of picking up one of these kits.
My quick review of the PM Model kit in 1/72 of what the box says is a Mirage IIIEA & Dagger. On opening the box the kit has about twenty-five parts. The moldings are chunky in appearance and some parts such as the pilot and bombs look more like blobs. The canopy almost has the look and feel of a hybrid injection/aftermarket part. The fit is very poor (looking at it I think it is molded crooked) and even after dipping in future it’s not very clear.
The directions show building either the IIIEA or Dagger but the kit does not offer the different nose sections that are needed to correctly model the appropriate aircraft. Instead the kit nose seems to be a cross between the two and it does not appear correct for either version (although in my opinion its closer to a Dagger). The kit supplied nose probe is way to large (clunky) and I made a new one from small plastic tubing and a sewing needle.
The cockpit fit is poor with a large gap behind the pilots seat. There is no detail of any variety for the seat, console or sidewalls. The wheel wells are way to shallow and have no detail as well. The landing gear is very fragile and the front wheel has no detail but the back ones have some.
The air intakes are just crude openings with nothing behind them. Unless you want to scratch an interior for them just paint the interior black. Even the intake nose cones stop at the opening themselves. The burner can has some detail but is plugged really close to the exhaust. The fuselage, wings and tail fit okay and the panels are raised lines but they do match on each side (I sanded them off and re-scribed them).
The decals are probably the most disappointing part of the whole process. I have the kit decals, and Microscale 72-459, available to use. After looking over both sheets and viewing actual images of aircraft from the period neither sheet is accurate but sections from both may be used if you don’t mind some inaccuracy (color and size of ID letters for example). The PM decals literally will disintegrate when removing them from the backing. As far as I know there is no decent decal sheet for an Argentine Dagger in 1/72 scale today.
The only other model in 1/72 is made by Heller but I heard the kit has some difficulties with the nose section pieces. The bombs and missiles are crude and the bomb rack placement is vague at best. I replaced them with a rack and bombs from then ESCI 1/72 Skyhawk kit I built earlier. PM only supplies two 500 liter drops tanks which are completely incorrect for Mirages/Daggers from the Falklands War. They used two or three 1600 liter drop tanks to reach the islands and back to Argentina.
Even with its faults, some scratch work and/or re-scribing it can make the model more acceptable even if it’s a three foot model (Looks okay from three feet away) the biggest plus of this kits is its price. Maybe there is a aftermarket canopy out there somewhere?
Here is the end result of my limited efforts:
Congratulations to everyone for a splendid Campaign.
Sincerely,
Brian
