Thanks for showing "problem areas". That will help in the future.
Regards
Steve
1:32 Roden GB 2008 Albatros D.I
Hatter50
KitMaker: 478 posts
AeroScale: 391 posts
Posted: Monday, September 15, 2008 - 07:19 AM UTC
RAGIII
KitMaker: 604 posts
AeroScale: 600 posts
Posted: Friday, September 19, 2008 - 12:09 PM UTC
Regards
Steve
It is good to be aware of "potential" problem areas! Just a note here, I am working on a review of this kit for an Internet Magazine. I am at about the same place as Larsa in construction. I have found that my assembly is vastly improved over my DIII build regarding the interior and fuselage. My wing to fuselage assembly went well with no hitches. Well, almost no hithces, I did create a misaligned joint on the fuselage by not waiting untill it was dry before attaching to the wing.That being said, I did not have to do any grinding.
RAGIII
Repainted
KitMaker: 1,058 posts
AeroScale: 1,004 posts
Posted: Friday, October 03, 2008 - 10:30 PM UTC
I don´t think the kits differ that much, so when you report no troubles in the wing joint You´re just a better modeller
than me
I will have my eyes open for that magazine
Larsa
Larsa
RAGIII
KitMaker: 604 posts
Posted: Monday, October 06, 2008 - 12:20 PM UTC
I don´t think the kits differ that much, so when you report no troubles in the wing joint You´re just a better modeller![]()
than me
Larsa
Not by a longshot! I think the difference lies in your altering some pieces for greater accuracy. I am building virtually straight out of the box. In the end you seem to come up with a superior build every time! I am continually inspired by your work.
RAGIII
Repainted
Posted: Tuesday, October 07, 2008 - 05:29 AM UTC
the lovley thing is that everyone inspire everyone.
The progress then.
The lower wing is glued in place and the pedal is positioned in. On this on I just forgot to add the cables to the rudder. You can see there was a little sanding on the top edge off the fuselage. When this happens there is no way to rescue the panel lines without the Olfa cutter, so new lines was rescribed with some old Dymotape as a helping hand.
The tank and ammo boxes are carefully lined up and dry fitted to get in line for the guns. I know I had problems with adding the guns after painting with the DIII kits, so this time I was dryfitting everything to line things up properly.
So from here there is tiny amount off filler that needs to be sanded, after all sanding the first coat off primer will go on. For the moment I am going thru all off my references, checking the lower anchor points for the wires in the fuselage. On the DIII kits they are sitting just too high over the lower wing. What I’ve found this is the fact on this D1 to.
Larsa
The progress then.
Larsa
MerlinV
KitMaker: 608 posts
AeroScale: 602 posts
Posted: Tuesday, October 07, 2008 - 10:24 AM UTC
Great looking build there Larsa.
That Cockpit sure does look busy.
Hugh
Hugh
Repainted
Posted: Wednesday, October 08, 2008 - 07:15 PM UTC
Thanks Hugh
The cockpit is always nice in these Albatrosses, I was planning to add some gloves on the seat. Had this in mind several times but never remembered to fix some out off putty. Yesterday I had the first coat off basecolour on the fuselage and lower wing. Hopefully it´s dry enough tonight so I can get on with the install off the guns. More pics coming soon.
cheers
Larsa
cheers
Larsa
RAGIII
KitMaker: 604 posts
Posted: Sunday, October 12, 2008 - 03:43 PM UTC
Thanks Hugh
cheers
Larsa
Larsa, Looking forward to the photos! Very nice so far!!
RAGIII
Posted: Sunday, October 12, 2008 - 04:25 PM UTC
Lars , the cockpit is really cool . To bad it has to be coverd up with the top decking and hide all the detail work .
I think Steve needs more empty beer cans !
Hatter50
KitMaker: 478 posts
Posted: Sunday, October 12, 2008 - 11:55 PM UTC
Terri,
Don't go sending me the empties............now FULL ones??????????
I might accept those.
Regards
Steve
Regards
Steve
Repainted
Posted: Monday, October 13, 2008 - 03:49 AM UTC
Next shipping will be unopened cans
Larsa
Repainted
Posted: Wednesday, October 29, 2008 - 02:47 AM UTC
Time to show some progress.
The whole fuselage have been sanded down for the second time. Primer then sand. more filler and sand, then more primer, you know the drill my friends. So now we can start up the basecolours for the final coats off paints.
A lastminute off adding an map to the cockpit.
Larsa
Larsa
Posted: Wednesday, October 29, 2008 - 03:08 AM UTC
Looking great Lars ! was there fit issues that you had to do so much putting and sanding ?
What paint scheme are you going with ? questions , questions and more questions !
Repainted
Posted: Wednesday, October 29, 2008 - 03:50 AM UTC
What paint scheme are you going with ? questions , questions and more questions !![]()
Hi Terri
No big fit issus just fixing things up a bit. The paint, living in Humbrolsland I´ll use the humbrols for the wings and the "slate grey" areas.
For the wood I´ll use asusual oils like yellow ochre and brunt Umbre over a base off Humbrol gloss Brown. For the last stages I´ll going to use varnish with a liottle touch off Humbrol Red wine crimson, just to get that "reddish" touch.
Larsa
Hatter50
KitMaker: 478 posts
Posted: Wednesday, October 29, 2008 - 05:06 AM UTC
It's a shame nobody is going to be able to see the engine. Even opening the top cowling doesn't show enough. How in the heck did they SERVICE the thing? Only those couple of round access doors to reach in. That area must have been really filthy and oily. If it lasted that long.
What is the "putty" on the end of the exhaust pipe Larsa?
I've got the Eduards PE set for my Abbie also. Wish there was more, but then dont need the framework. Liked to have seen more for the gun feed chutes.
I'm watching closely here.................
Regards
Steve
Regards
Steve
Repainted
Posted: Wednesday, October 29, 2008 - 07:16 AM UTC
The putty around the pipe is just some Milliput my favorite stuff.
Larsa
Larsa
Hatter50
KitMaker: 478 posts
Posted: Wednesday, October 29, 2008 - 08:25 AM UTC
i figured it was milliput....but what for?
Steve
Steve
RAGIII
KitMaker: 604 posts
Posted: Wednesday, October 29, 2008 - 12:02 PM UTC
Larsa,
Looking very good! The engine cover appears to fit better than the Albatros DIII cover as I found that my D1 did? Glad to see you filled in around the cockpit but left the forward area with a gap. It seems to me that the real bird was exactly as you have assembled the kit.
RAGIII
RAGIII
Repainted
Posted: Thursday, October 30, 2008 - 05:15 AM UTC
Sorry Steve
Just lost those why´s and but´s.
When I was drilling out the end off the pipe the bit just went straight through, So I´ll had to do some repairs. In my eyes the end off the exhaust looked just a little bit thin so when the Milliput was soft I corrected that to. Sorry Steve.
RagIII
The top cover has a better fit than the DIII, It was my own fault sanding down just to much around the cockpit, little repair with some plasticard and Milliput.
Larsa
RagIII
Larsa
Hatter50
KitMaker: 478 posts
Posted: Thursday, October 30, 2008 - 06:53 AM UTC
Larsa,
No sorry about it......I just wanted to know what NEW thinggie you had going there. If i was going to have to add something also to mine, like some kind of aspestos covering.
And i hear ya about having to do repairs. That's my middle name.
Regards
Steve
Regards
Steve
Repainted
Posted: Monday, November 03, 2008 - 06:23 AM UTC
Progress, progress
Hi
This is what’s happened sins last time. The fuselage had the first coats of basecolour, and yes there was still some minor thing aft the cockpit to fill and sand. The wings have almost got all those tiny strips masked up for the preshading. Yep it’s just that boring it’s look like, but it´s effective.
The enginecovers will get a coat off silver, so the paintchipping can get a sweet look.
So from here there is just to give the fuselage that last bit off sanding and a brand coat off paint then I can bring out that old cans off woodgrainingcolours I’ve got last Christmas
Larsa Q
Hi
Larsa Q
Posted: Monday, November 03, 2008 - 08:51 AM UTC
I can't wait to see your wood grain effect , It is simply outstanding !
Hatter50
KitMaker: 478 posts
Posted: Monday, November 03, 2008 - 09:03 AM UTC
Boring???? No....looks kinda interesting to me. I'm watching............
Regards
Steve
Regards
Steve
RAGIII
KitMaker: 604 posts
Posted: Saturday, November 08, 2008 - 12:49 PM UTC
Lars,
Looking forward to the wood grain! I am planning to do this one myself on my build. Will be taking notes!
RAGIII
RAGIII
CaptainA
Posted: Saturday, November 08, 2008 - 01:39 PM UTC
Looking great, as always.
Just a note. The leading edge of the wings are solid. That is, they are a solid plywood. The way you have them taped looks a little, uhh, off.
