Okay...Weekend over..ish.
Progress so far...ups and downs gets me to this point. Now I know the blue & green is bright, I'm not sure how accurate WNWs colours are, but everything seems a little grey/flat. Once they are worn/weathered in I'm sure things will tone down. Besides she will be a nice clourful addition to my cabinet.
Fuselage sitting on its U/c. I did a little wear & tear on the wheels and U/c, more to do but I wanted to experiment with Tensocrom. I made a Faux Pas on the build but I'm not saying what it is..I leave that to the eagle eyes
The Blue & Green are Citadel paints I really do like this brand, colours are different and the names are somewhat odd but for quality they are good.
I had a lot of bleed issues cos I rushed the masking and the artists masking fluid I used was temperemental, set like stone....must be a reaction with acrylic
Okay, tail surfaces, painted with a slight change of tone to the fuselage I'm hoping its subtle but enough to indicate the difference between wood and fabric once done. if you peer real close you can see some of the nailwork...the next one I'll do before she is all together and half painted..lesson learned?..NO of course not
top wing, decalled, they sat nice, no problems but seem thick. probably because of the white. I'm intending to mask and spray the feint outline of the earlier mational markings as if they show through, I had toyed with the idea of double layering the decals but thought it would be too thick to get away with. I dont know if you notice but you even get the data plates for the wings...attention to detail by WNW.
Upper wing rad position, I shaved out around the rad a little, it was a very snug fit and most pics show some gap between wing structure and the rad itself. Also I dipped the fabric behind the rad on the upper surface...AMD and Jamo Kiwi's posts of Tval DVA detail shots is .....grrr
(much appreciated really mate)
the rad needs finishing BTW.
but basically this is it...WNW say its natural metal, I'm not so sure thats always the case.
A couple of shots at my attempt at a laminated prop. I need more practice...this is a nendorf prop and the kit should have a Wolff but props got swapped and I like this one, it makes a change from all those Axials on my other builds. That said I'll try painting up others...two kits with 4 props each leaves a lot of very high quality props to toy with.
So thats it so far folks. I intend weathering/wearing her in, this particular plane seemed to have a little service behind it before this point so it will lend itself nicely to wear and tear.
