Thank you very much for your nice words.
Hello,
Both anti-skid zones are made plastic stretched stuck on a piece of adhesive tamiya and sanded in dish(flat) to flatten a face. It is rather easy and fast to make:
The "drift" are in plastic card 0.25mm stuck on the side of the float in a hollow accentuated with scalpel.
They will be painted in blue grey. 1x (XF 82) + 2 x white. what is alike in FS 83 a lot....
The radiator is too small in my opinion and badly placed. It is embeded in the wing [ u ] and not [/u] in front of the wing as on the Kit. We see him(it) very well on certain photos.
So we cut:
It is fixed between the second nervures right and left (by leaving of the center).
I enlarged my radiator, it spends 16 in 17.8mm. Its shape changes so a lot: sharp in front, "sharp" in the summit.
The bottom of the radiator is not flat but has the shape of a flat triangle in the truncated summit (you see?). The shape of the radiator depend on the plane and of period.
Card(Map) blows up 0.5mm
Baguettes rounded off to give the shape of the summit.
PART supplied a beautiful series of shutter horizontal very fine but I saw it on no photo....I don't use it.
A PE wire netting remains very big. I make a new on with a tea bag.
The motor hood adapts itself rather badly (I find).
It must be put after the engine. What obliges us to make the work of filling sanding then paint with the engine in position. Very difficult for me.
I cut the hood in two in the horizontal plan. The low part is stuck little by little by leaving of bottom.
When everything will be ended (retouch are not simple) I shall put the engine, the top of the hood and the details which disappeared during the cut.
Regards.
