Well, now you open the Pandora's box... That's somehow tricky to answer. The bottom line is that the cleanup procedure has eaten up the plastic in that section and it simply "boiled". So I had to repair that. The other side of answer is more dubious and it might be that I am starting to file the case against me. I don't have many arguments, and I don't want to be mean quarreler. However, I observed many photos of the Oeffag Albatros, and it seems to me that the Eduard kit has overly accentuated "Y" shaped line... the photos are just for orientation (and I am aware that it very much depends on the original angle, etc.) I inserted the plasticard sheet only to slightly "tame" the curve, and get a bit wider ending to the rear of the fuselage, which seems to be more correct. I am also aware that I may be completely wrong, but I was also studying the photos of Mayerhofer's replica aircraft (build almost to original specification), and it also seems that the rear curve is slightly less prominent, and the rear is also wider. But this may be completely wrong judgment... and hey, now it is there!
PS. Thank you for the wonderful and useful article!!!
And now back to the reality... She is not the prom queen, but you wouldn't expect that from a resurrected bird, would you? The primer also revealed several minor mistakes, which I will repair tonight, and (possible) put the base coat on.
All the best,
Entoni
