Here lies the 1st issue I had to deal with, what color to paint the interior. Research has shown that all Naval Interior colors were aluminum lacquer for pre war to early production models of the Vindicator and Devastator. After the Pearl Harbor attack, through the Battle of the Coral Sea, and up to Midway, all Naval aircraft were repainted. That included the interiors to what is commonly called Bronze/Interior Green. The issue is that not all planes were painted, and certainly not all the interiors were converted according to the allotted time schedule. I'm going on the assumption that both depicted aircraft in the kit were repainted to Bronze/Interior Green.
Before I started my painting procedures, I had to do a little PE work. Two hinges and a bracket for the radio were added, and the large front fuselage section that when the doors are opened, allows the pilot to see out of a large bottom window.
I primed the interior of the fuselage and all the interior cockpit parts flat black to help with color modulation and shading. I next airbrushed the same parts a custom mixture of Tamiya Acrylic XF-4 & XF-5 thinned 2 parts thinner to 1 part paint. The mixture flowed like when I used enamels. Applying several light coats gave me the finish I was looking for. Unfortunately, this set of pictures I once again took the easy way out and used the pop up flash, which just killed the drybrushing and the dark interior green color. Next series of pictures I'm going back to natural light and a tripod for the proper effect. So please bare with me on the colors.
Next I glued up the PE section for the lower fuselage. Hindsight would have made it a lot easier to glue it up, then paint it, as I'm doing some needed putty and sanding that will destroy the paint anyway.
Finally, I painted both instrument panels flat black, then installed each decal instrument, and used Pledge to make the clear gloss lenses.
I'm on my last of 3 weeks vacation, and hope to get in quite a bit of modeling time besides working on the ever growing Honey To do list for around the house.
