I've been working on the basic fuselage assembly. The cockpit and front wheel well get glued to a separate front lower fuselage section, not to the fuselage. Interesting concept. Makes for a "No Brainer" in getting the front wheel well properly aligned. That in turn gets glued to the other bottom fuselage section comprised of the full main wing assembly. Test fitting showed a nice joint, but it looks like it would be rather weak, so I added a few pieces of sheet plastic on the top to strengthen the joint.
Here you can see the joint which has been sanded, puttied, and re-sanded.
Once that assembly dried. I glued it to the one piece upper fuselage. The fit was next to perfect. Next I test fitted the two intake sub assemblies. They fit ok, but needed a lot of tweaking. I got them the best I could, but they needed sanding, then some Green stuff, then more sanding to get the fit flush and smooth. Also there is a inflight refueling hatch on the top of the fuselage that is not used for the Navy version, but rather a side fuselage unit. Academy gives you both a top receptacle and a blank panel, Once glued in there is a rather large seam line around it. I filled the area with Vallejo filler, then wiped the bead down with some pressure applied. The result is a slight recess panel line.
The joint line between the wing and intake needed a little filler on one side only. For this I used Vallejo's white putty, which sure has the feel and look of caulk. I applied a very thin bead, then with a damp Q-tip I smoothed the area. Let it dry, the result was a perfect joint line with no sanding needed.
The rear section of that fuselage joint on both sides did need some attention including more green stuff.
The exhaust area has a insert that forms the top of the fuselage section right about the nozzles. It's a weird fit, but actually required just a light bit of sanding to blend right into the fuselage. The rest of the exhaust area had it's issues. the main exhaust area had a slight roll to it that caused a lip on both sides. I added a few small pieces of scrap plastic cut from sprue to help with that issue, but I came up a little short and once again had to sand, putty and sand. There were a few injection pin marks on the arrestor hook that needed attention, but they were very minor.
Here's what the basic fuselage looks like:
Right now I'm at a stand still waiting for the Hyperscale stabilizer set & Air Conditioner intakes to arrive. Our own Jessica once again came to my rescue, and has sent me a set of each. I'm really curious to see those resin stabilizers compared to the kit ones. The kit parts do look great. In the meantime my attention will focus on the weapons and stations, as they're a kit unto themselves.
