It's been a while since my last update, but that's because I've been strictly decaling, including the more then a hundred stencil decals that come with the excellent Cartograf decal sheets. Well, I finally finished the topside of the F4B, leaving just the lower part to decal.
I applied all the decals, no matter their size using the Microscale system:
soak decals in warm water
apply Set to the surface
slide decal on to the surface
apply Set to the top of the decal, and leave for 2 mins. Then pat & roll Qtip to get any trapped air out.
Apply Sol and leave alone To dry.
Every single decal snuggled down into any recesses they were over perfectly.
I did have some major concerns with the Sundowners massive tail sun rays and the full multi colored rudder decals. On the 1st side I cut the main decal into two pieces to aid in placement, and cut out the large clear section in the rudder decal. On the other side I cut out every ray, so that there is no clear film to deal with. In either case, the Cartograf decals laid down so well, that wrinkles and flash weren't an issue.
Then came the dreaded sharks mouth. I just knew that I was going to have issues with them as there are compounds curves that just won't make it an easy task. The Shark Mouth does come as a separate upper and lower decals, but I still had little confidence in my ability to get the job done. I started with a upper decal, and the issues just jumped out at me. Struggle I did. Finally I decided to cut the decal where there was either a major bubble or roll that would eventually become an unsightly crease. I then flooded the decals with Set over and over till they started to lay down. Cut and used a needle to get rid of the rest of the issues, then started with coat after coat of Sol. Eventually I just decided to let the decals fully dry and see where I was. To my surprise, the next day, they were really pretty decent. Did a few more touch ups, another coat of Sol, and let them dry. Here's the results:
I did have some touch up painting to do where the two jaws meet. This isn't the fault of the decals, it is 100% my fault. I just plain screwed up with their placement.
Here's a few pictures of the overall F4B.
