TAIL DONE: NOW FOR SOME CLEANUP ITEMS AND GUNS!
It seems hard to believe, but I have finally "finished" the interior. I will show you the tail as finished and then discuss the cleanup items and the handheld guns that I'm going to use.
Here is the stbd. side.
I personally like the seatbelts, which were intended to swivel forward and be connected over the gunner's lap.
Here is the port side.
I'm not sweating the minor blemishes: the view through the tail gunner's glass will be, at best, impressionistic and this more than gets the job done.
Now on to what still needs to be done before I close this up.
First, there is a bomb bay door actuator that I have to reinstall on one of the bulkheads. Happily I somehow managed to have a spare which will go in there.
I also need to put some styrene strip along the bottom of the catwalk.
Next, there is a bottle which I have to re-glue into the cockpit section adjacent to the top turret. I suppose all the detail there raises the question whether I should simply hand place the top turret into the aperture so that if one lifts it out and looks inside more of this can be seen. I probably will, but it will depend on how solid the non-glued fit is for that subassembly.
In the nose I have to reinstall the starboard after most window curtain.
Then there are the handguns for the nose and elsewhere. After searching eBay I came up with a second issue of these complex handheld guns available from Aries (same but grey resin, silver looking metal). They will give me the the number of guns I need.
You will see that the brass parts make each of these guns almost a kit in and of itself. I will use them for the three guns in the nose, the radio room gun, and the waist guns. However all will have Karaya metal barrels rather than the resin ones pictured here.
My current plans for getting together with my North Carolina friend, barring unforeseen circumstances, have me driving down there around December 15. This will give me sufficient time to do the cleanup items and invest the necessary time on the handheld guns. For the present I'm probably just going to do the cheek guns in the nose and save the rest for "final construction."
What I hope we will accomplish in North Carolina is as follows.
First, get the fuselage halves together!
Second, install the radio room roof and feather it in so that it appears "seamless." This is probably the one thing in the whole build that I am the most paranoid about.
Third, install the pilots' roof. Here we have to make some decisions about the main cockpit windows. My inclination is to use the Edward brass framework rather than kit parts, with clear styrene windows. This would allow us to position both the pilot's and the co-pilot's windows open to allow a better view into the interior of the cockpit. However, this job will be fiddly.
Fourth, install the ring around the nose that has the rivets showing so that there is an attractive view of the edge of the nose opening looking in through the "Plexiglas."
Fifth, install other fuselage windows. These will include the ones in the roof above the nose, and the two radio room windows. This will also be a bit of a challenge but it has to be done.
Finally, I hope to leave with a fully primed fuselage ready to paint in final colors. This will require not only filling the seams in the fuselage halves themselves but also cleaning up some areas of the exterior fuselage where I have smeared glue, obliterated panel lines, etc.
So far as reinstalling panel lines is concerned, even though the kits lines are raised, I will probably scribe the missing panel lines in rather than duplicate the raised lines. Candidly, I've done this on some other kits and in my view (literally!) it's really difficult to see where the panel line is "raised," and where it is cut. One must look really closely to see this.
So, let me close with with the observation that I still have plenty of work "cut out for me".
