Time for another update which is rather long, as I have covered a lot of ground since my last one. I've decided
to go with the Black Basing technique rather then pre-shading. However, I'm using a two part approach of priming
with AMMO-MIG acrylic gray primer, then using Tamiya XF-1 Flat Black applied in a blotchy random pattern
before the 1st color coat is applied.
The fuselage has reached the stage of being masked, and the main tail elevator section glued into position, so it
was prime time.
One thing I did notice is that Revell has molded the rudders and elevator tips without any recessed line to
replicate the real world separation.
So using a micro saw, followed by some emery cloth, I made a cut along that demarcation line.
I then started working on both wings. I cut out the upper and lower Ailerons as I wanted to position them in a
more natural position.
Then I glued the top and bottom halves of the Ailerons together and a face plate made from 1x3 strip plastic, as
well as gluing the wing halves together.
Once dry, I glued the Ailerons in the grooved slots with one up and the other one in the down position.
I also glued up and test fitted the engine nacelles. The Revell engine exhausts are not nearly as detailed as the
Quickboost resin offerings, so I replaced them with the Quickboost ones.
The main wheel wells have some molded in detail, but for their large size still are quite barren looking.
I added a fuel line, various electrical and hydraulic lines, a few braces, and some bits and pieces following a
few pictures as a guide.
A coat of primer blended all the various parts and materials quite well.
Next up I AB'd the blotchy flat black base but forgot to take a few pictures of it. To the best of my knowledge
from what information I could gather, the wheel wells, like the bomb bay was painted with GZC. Naturally, Tamiya
doesn't make that shade, so I mixed Tamiya XF-3 Flat Yellow and XF-5 Flat Dark Green 2:1.
the color looked a little to lite, so I decided to change the mix ratio to 1:1
I added a enamel wash, followed by dry brushing Model Master light Ghost Gray
And now you're update on the PV-1 build.
