Since last week's update, I've managed to accomplish quite a lot. So much so, that I can actually see the finish line off in the distance for the 1st time.
Up next was the assembly of the small 6 bomb payload, which was then painted Lifecolor faded OD and then a wash of Model Master Raw Sienna. The bomb were then installed.
The main gear struts were assembled, then primed with Gray AMMO acrylic primer, then given a few light coats of Alcad 2 White Aluminum, The Oleos were hand painted with Testors Metallic Buffing Steel. The molded on brake lines which really look excellent were painted a dark gray to simulate rubber. Once dry, a heavy wash of Model Master enamel Flat Black for an oily effect, and then sealed with Testors Metallic clear sealer.
I replaced the kit tires with Ultracast Diamond pattern tires, which had a much more defined tire pattern, as well as a higher degree of wheel detail.
Finally, the under wing gas tanks were glued into position. the Identification lights were each painted the appropriate color, while the lenses were made using Microscale Krystal Klear.
The bomb bay doors are comprised of a pair of doors for each side. Since I wanted to have the doors in the open position, the installation sequence in the instructions was vague even with the two pictures included. They would have you glue the actuation rods into the bomb bay, the glue up the doors to them. After a few min of contemplation, I decided to make each bomb bay door a separate assembly, then glue them into position.
I glued both halves to the center folding mechanism, then when almost cured, I carefully glued each end together. Then glued in the actuating rods. The rest of the doors in each pair don't touch each other, so the whole assembly is more then a little finicky.
The top fuselage turret was supposed to be installed before you glue the fuselage halves together. I was 100% positive that I would have broken off both MG barrels more then once, and likely damaged the painted turret, so I left it off till now. This required a fair amount of filing and sanding to get it to now fit.
Next up will be the final detailing of the big twin radials, and their installation.
