I read that it may be finished as an ambulance during the French campaign. Hope it qualifies?
Tat
Hello,
First order of the build -- the suspension.
Had a bit of a challenge in the bogie assembly as it doesn't line up easily. Next came the tracks, 200+ in all. Quite disappointing as the plastic was brittle and I broke a fair amount of track links when cutting from its sprues. Hope that there is still enough to complete the build. Now off to cleaning up these tiny bits!![]()
Paul, which colours did You use for Your boat? They look flawless.
Hello Paul,
nice update of Your boat. How have You managed it, that there is nearly no seam visible, after glueing the prepainted front section piece?
Oliver![]()
Oliver, that Japanese emblem is tops -- did you use DIY mask for it?
