The underside of the Mirage has what looks like a landing light to my inexpert eye. The kit offers a clear lens but nothing behind it. I rummaged in the spares box and found an unused part (from an old Tamiya 1/48 scale T34 as it happens) that had roughly the right shape to simulate a light. A hole in the part was filled with an odd bit of plastic card and then the interior was washed in a few layers of white and yellow paint. Its not exactly an exact replica, but its good enough for this part of the kit, and definitely better than a hole.
With that little job done it was back to some serious engineering. The wings and lower fuselage align quite well but there is a gap. I had a gluing plan (at least in my head), which started with the areas most aligned and with least gap, then moved outwards. That meant cementing the wheel wells first and then working back towards the trailing edge. Then I cemented the join from wheel well to leading edge. I got one wing fixed this way, and then did the other, leaving about five minutes between each section for the glue to set a little. Some squashing and squeezing of parts softened by the cement filled a few gaps with the best results being at the rear. There is some filling to do but its not as bad as I feared it might be, and in fact there’ll be no filler needed in places. Well done Mr Italeri, this bit works well.
A quick test fit of the upper fuselage onto the complete underside showed that everything was as good as it could be. There appears to be a step where the parts join, but that might be just because I am holding it all together in these shots.
Now I’ll let the glue dry over night. Tomorrow the fuselage will meet the wings and underside properly. Hopefully they will get on and it will be love at first sight.
