Hi Everyone,
Had a busy couple of days, so not much modelling accomplished. Yesterday I built a retaining wall for my house, and today we drove hither, thither, and yon searching for items needed by my 3-week-old granddaughter. Consequently this is a mini-update.
Kobus and Brian, I could tell you many things about foiling that might make you think I was trying to sell it to you. But here are three simple truths:
1. You will foil 15-20 1/48 scale aircraft for less than the cost of two 23ml glass pots of Tamiya acrylic paint.
2. You cannot ruin a model by the foiling process. Worst you could do is scratch the plastic with heavy-handed knife-work.
3. Once you complete one with foil, a bright, shiny, new world (or dull, if you prefer) of late WWII and Cold War aircraft will open up before you.
There is nothing to fear.
Anyway, here we go:
I had a little time between things this morning to test foil and a new product on a spot that I knew was going to be super-difficult.
This one didn't turn out too bad. I knew the aft-most part would be the hardest of the whole bird.
Aft-most part of the barbette defeated me. I felt from the beginning that there were too many curves and the foil would be pulled into too many directions for my skills to manipulate. So, I thought ahead:
(oh, and I apologize for the orientation) (It's that Apple vs. Microsoft thing again!)
After three failures on the same spot of three different pieces of foil, I knew struggling further would be pointless. So, I broke out the BMF.
On the first attempt, the BMF stretched in ways the foil wouldn't.
It also highlighted that a bit more sanding was required on that part of the barbette.
So, that's all I accomplished today model-wise.
I reckon that BMF is a fine product. But at 10 Dollars AU for a little sheet, I imagine it'll stay in reserve for spots that I can't beat the same old way.
Thanks for looking!
Gaz
