A nice-looking G.50 you got there!
Yes, I think I should be able to finish both before the deadline.
The Bf-109 shouldn't much trouble, except for the camouflage perhaps. And those landing gears should also be fixed. The axels are attached to the gear legs at an angle so the wheels end up at a right angle to the ground. That shouldn't be too hard to fix.
It's the LaGG that has more of an issue with it's landing gear. While parts are nicely detailed and fit right, someone must have messed up with the gear wells. The gear legs have a typical pin at the end. One would think that it attaches to corresponding holes in the wheel well. Wrong! What you find in the wells, are rectangular openings about 2mm wide.
Guess I'll just have to glue in some styrene and drill two holes for the gear legs.
Contrasting the trickier build, painting it will be much simpler. Back to the black/green Finnish camo, but to add a twist, captured planes had a cool splinter scheme. One site had great four-view drawings and I got the idea of re-sizing them in photoshop, then just printing them out and cutting the masks.
But... Apparently, re-sizing the pics has to be done through trial and error, since the dimensions of the pic don't match the print's. No matter if you change the print size or the actual dimension of the file, it's all guesswork.
You can set the dimension in centimeters, pixels or parsecs (or something), but it's no use if I can't set the physical print size I want...
Of course, using a photocopier to take suitably sized copies of the prints is will work just as well, but would have been so convenient to just set the required size and hit the print button in photoshop.
