Having this week off from my hectic work schedule, I've decided to attempt a few of the Campaigns. With no Finnish aircraft lying about in my stash, I decided to head to my LHS and pick up anything with Finnish markings,.... this is what I brought home...
Not having followed the group build (again, due to my not being home over the last few months) I was oblivious to the headaches Fred had acquired due to this Classic Airframes gem. I opened up the model today and started with what I always do first, checking the wing root fit with both the fuselage and the wings taped up. Not bad,.. that is until you start to dry fit all the interior bits. This is where it got nasty! I quickly tossed aside the instruction sequence, and concentrated on the fuselage halves and the wing /undercaridge., figuring that if I get by this , all else should fall into place. This model allows you to build the interior/cockpit seperately from the fuselage, and then once completely painted, insert it through the assembled fuselage. If you follow the building sequence, it will shorten your lifespan (just ask Fred!)
Here are some additional photos of my first day back at the office...
I haven't given any thought one which markings I'll use, I figure I've got bigger issues to deal with over the next few days.
Frank
