OFFICIAL: Grumman Campaign
Dragon164
#226
_VISITCOMMUNITY
British Columbia, Canada
KitMaker: 1,909 posts
AeroScale: 508 posts
Posted: Saturday, December 27, 2014 - 06:47 AM UTC
The problem I see is that the plug with or without the pin is the wrong length so once the engine is finished I will have to work out the spacing to install it correctly. I do not know why there is not some sort of explanation of how it is supposed to go together in the instructions.
Cheers Rob.
Dragon164
#226
_VISITCOMMUNITY
Posted: Saturday, December 27, 2014 - 11:53 AM UTC
Some progress on the engine and some weathering.
Cheers Rob.
Staff MemberAssociate Editor
AUTOMODELER
_VISITCOMMUNITY
New York, United States
Posted: Saturday, December 27, 2014 - 07:03 PM UTC
Rob,
Just fantastic progress now. I'm fully confident that you'll make it to the finish line with some time to spare.
The wheel wells are really sky. They look quite good. And the engine is coming alone nicely. I will have to admit that the PE wiring harness does look better then I thought it would, and it's certainly a lot quicker process then making and installing one wire at a time.
Have you test fitted the engine yet to see if it correctly fits with the cowl? Did you take Matt's suggestion about installation?
The pin wash really adds tremendously to the overall look of the aircraft.
tinbanger
_VISITCOMMUNITY
Ontario, Canada
KitMaker: 2,507 posts
AeroScale: 1,814 posts
Posted: Saturday, December 27, 2014 - 10:07 PM UTC
Here is my completed entry:-
F6F-5 White 71,
Lee Bob McCuddin, VF-20. USS Enterprise, October 1944
Almost factory fresh!
Thank you Joel for you paint colour information, I like this one better than my first attempt.
Richard.
AUTOMODELER
_VISITCOMMUNITY
Posted: Sunday, December 28, 2014 - 06:37 AM UTC
Richard,
You're quite welcome. The F6F-5 came out brilliantly!! Just an excellent all around build and finish.
Cam
#275
_VISITCOMMUNITY
KitMaker: 174 posts
AeroScale: 19 posts
Posted: Sunday, December 28, 2014 - 08:12 AM UTC
Getting way too close to the deadline. Tomorrow some future and the decals, it will be close but I should make it.
Dragon164
#226
_VISITCOMMUNITY
Posted: Sunday, December 28, 2014 - 01:08 PM UTC
Well done Richard!
Looking good Cam!
I have had some up's and down's
I had to drill through the engine with a drill press in order to get the hole in the back in the right spot I also had to make a new prop shaft by grinding down part of a plastic rod chucked in my dremel as the size of the post on the resin bit is not the same as the hole for the prop. I then had to cut the front projection on the firewall in order to fit the resin bit in. I have no idea why they made it this way and left the figuring out to the modeler. With that done I finished painting the engine added the PE parts and a little grime. I finished painting and decaling the prop and painted the landing light chrome, that is where I ran into a problem while masking the light the tape took the roundel with it luckily I have some as I picked up the British roundel set for Spitfire's from Eduard however I have misplaced the canopy.
Cheers Rob.
WARLORD
HISTORICUS FORMA
_VISITCOMMUNITY
Warszawa, Poland
KitMaker: 1,923 posts
AeroScale: 100 posts
Posted: Sunday, December 28, 2014 - 03:25 PM UTC
Finished:
eMan
#298
_VISITCOMMUNITY
Hong Kong S.A.R. / 繁體
KitMaker: 1,182 posts
AeroScale: 351 posts
Posted: Sunday, December 28, 2014 - 04:43 PM UTC
Progress update, just finished to airbrush the aircraft.
AUTOMODELER
_VISITCOMMUNITY
Posted: Sunday, December 28, 2014 - 09:29 PM UTC
Marcin,
Well done, and congratulations on crossing the finish line for our Grumman Campaign. Please don't forget to post 2 pictures in the Grumman Campaign gallery to qualify for your ribbon.
WARLORD
HISTORICUS FORMA
_VISITCOMMUNITY
Warszawa, Poland
Posted: Monday, December 29, 2014 - 03:04 PM UTC
Hi Joel,
I've already uploaded them but anyway thanks for reminding.
AUTOMODELER
_VISITCOMMUNITY
Posted: Monday, December 29, 2014 - 05:49 PM UTC
Hi Joel,
Marcin,
Thank you.
Dragon164
#226
_VISITCOMMUNITY
Posted: Tuesday, December 30, 2014 - 08:42 AM UTC
It came out well! Marcin.
I replaced the roundel under the wing and painted the canopy all the clear bits have been tinted, although I dropped a small green lens This is where it stands now. Because of work I will not be able to get the last little bits done till the 1st.
Cheers Rob.
Tomcat31
#042
_VISITCOMMUNITY
KitMaker: 2,828 posts
AeroScale: 1,720 posts
Posted: Tuesday, December 30, 2014 - 04:59 PM UTC
Wow some great entries here. Unfortunately I haven't had enough time to update my blog but work has continued here and there on my Tomcat.
Sadly it won't be finished in time for the campaign as I could have done with an extra couple of weeks but it will be finished in my blog. Here's the stage it was up to last night and ready for the decalling to start tonight.
AUTOMODELER
_VISITCOMMUNITY
Posted: Tuesday, December 30, 2014 - 07:34 PM UTC
Allen,
I was wondering what happened to your build, as you were our only F-14 build. Glad to hear that you're ok, just have been busy with other things.
Have a happy and healthy New Years.
AUTOMODELER
_VISITCOMMUNITY
Posted: Tuesday, December 30, 2014 - 08:09 PM UTC
Rob,
Your Hellcat is 99% complete. Please post 2 pictures in the Gallery section so I can award you a ribbon. Just finish it up with the few little bits when you have the time.
eMan
#298
_VISITCOMMUNITY
Posted: Tuesday, December 30, 2014 - 08:20 PM UTC
Dragon 1/72 F4F-4 finished.
rochaped
_VISITCOMMUNITY
Lisboa, Portugal
KitMaker: 679 posts
AeroScale: 669 posts
Posted: Tuesday, December 30, 2014 - 10:49 PM UTC
Joel,
Tried to upload a couple of photos, JPEG FILE, awhile ago, but they don't shown up on the album, at least on my mac. The message read upload successful...
Pedro
Removed by original poster on 12/31/14 - 17:59:51 (GMT).
AUTOMODELER
_VISITCOMMUNITY
Posted: Tuesday, December 30, 2014 - 11:55 PM UTC
Joel,
Pedro
Pedro,
I just checked at your pictures are there under eman.
JClapp
#259
_VISITCOMMUNITY
Massachusetts, United States
KitMaker: 2,265 posts
AeroScale: 1,715 posts
Posted: Wednesday, December 31, 2014 - 01:19 AM UTC
eMan posted pics this morning, Wildcat wings folded.
I can't see Pedro Rocha's pictures. they may have gone into a different folder. Pedro you must try upload again.
Dragon164
#226
_VISITCOMMUNITY
Posted: Wednesday, December 31, 2014 - 01:57 AM UTC
Joel, I have uploaded a couple of pics they are not the best but I only have half a hour before I have to leave for work.
Cheers Rob.
AUTOMODELER
_VISITCOMMUNITY
Posted: Wednesday, December 31, 2014 - 02:37 AM UTC
Rob,
Good enough. You did a great job.
Jonathan, thanks for catching that. If the pictures don't show up and it says successful, it usually means that Pedro tried to upload pictures larger then 1024x768. That use to happen to me all the time. I'll PM Pedro and let him know.
macotra4
_VISITCOMMUNITY
Illinois, United States
KitMaker: 110 posts
AeroScale: 88 posts
Posted: Wednesday, December 31, 2014 - 04:13 AM UTC
So I was able to finish it. In my time zone it is 5:11 PM so i do have few hrs yet to finish. Happy New Year to all of us!!!
JClapp
#259
_VISITCOMMUNITY
Posted: Wednesday, December 31, 2014 - 05:40 AM UTC
nice! USS Enterprise by chance?
Excellent last day of an exciting campaign!
