Interesting choice, Eetu. I am looking forward to see it build. I have never heard about this kit or aircraft before!
Thanks.
Being a trainer and not a glamourous fighter or bomber type, VL Pyry hasn't been subjected to as much attention as it should have, as it's perhaps the most successulf Finnish aircraft ever built so far. Designed prior to WWII in the late 30s, it was one of the primary trainer aircraft used during and after the war. The last flight of the type was made in 1962.
But enough with the history lesson and on to the build progress.
Contrary to the instructions, I glued the cockpit framework to the fuselage sides instead of the cockpit floor. Perhaps all wrong, but assembly looked much easier this way, as supergluing the framing to the floor at the correct angle seemed daunting. Anyway, the cockpit opening is pretty small and it won't be very visible in the finished model.
The framing didn't seem to conform to my reference photos completely, but as I have decided not to stress anything too much with this kit, I left them alone.
The styrene strips help gluing and aligning the cockpit floor and rear shelf.
Pretty nice fit with the fuselage halves. As I was dryfitting, I did the initial trimming and dryfitting of the vacform canopy at the same time: nice fit again, although the windscreen area requires some more careful cutting and sanding to minimize the need for filling.
The two canopies provided in the kit would make it easier to pose them opened, but I'll keep them closed on this one. Perhaps I'll do it on another one when I let myself go crazy adding details. (although there's one thing I think I'll just have to make: the prominent roll cage between the seats, omitted from the kit for a reason or another)
The cockpit floor ready for priming. No rudder pedals were supplied, so I made simple items from styrene rod, scrap PE and thick foil.
Control sticks were also missing from the kit, with directions to make them simply from lengths of styrene rod. Quite strange IMO, as the reference photos in the manufacturer's website clearly show the front cockpit equipped a spade gripped stick and the rear one having a simpler stick with a ball in the end. Some more scratch-building ahead.
For the missing set of seatbelts, I couln't find anything in my spares that would have fitted in with the provided PE well enough, so I decided to adapt some French seatbelts by Eduard:
